It is currently Oct Tue 16, 2018 7:27 pm
 Post subject: Cunningham C-11
PostPosted: Dec Sat 02, 2017 4:05 am
Is the Cunningham C-11 tube any better than the RCA WD-11's? If the filament blows on a C-11, can it still short the B voltage and blow up a radio?
Dan
I know just enough to be dangerous.....
(Member - Michigan Antique Radio Club)
 Post subject: Re: Cunningham C-11
PostPosted: Dec Sat 02, 2017 5:03 am
Both C11 and WD11 are the same and made by Westinghouse.
If the filament blows usually it's stopped from shorting by hitting the grid. It could short to plate which might damage the B supply..
PostPosted: Dec Sat 02, 2017 9:11 pm
Thanks again for your help Norm.
Dan
Dan
PostPosted: Dec Mon 04, 2017 12:59 am
They will work fine in your Aeriola if you have one. With moderate or occasional use, it ought to last as long as you do, if care is taken each time you bring it up. I would have hoped that by the time they moved from the brass base tipped ones to the C-11 production, they might have learned how to move beyond some of the weaknesses, or production improvements, but maybe not.
PostPosted: Dec Mon 04, 2017 3:14 am
Thanks for the input wazz!
Dan
