It is currently Oct Fri 19, 2018 6:29 pm
 Post subject: Is this a capacitor?
PostPosted: Dec Sat 02, 2017 4:31 am
Sorry for the blurred photo. Color bands orange orange white silver.
 Post subject: Re: Is this a capacitor?
PostPosted: Dec Sat 02, 2017 5:07 am
It is a 3.3 PFD ceramic cap. As long as it's not physically damaged, it should be fine.
Bob
Life is too short to be serious all the time.
PostPosted: Dec Sat 02, 2017 5:37 am
That's one type of tubular ceramic cap.
Those were available in extremely small values, including <1.0 pfd.
Guaranteed to be good unless broken.
- Leigh
73 de W3NLB
http://www.AtwaterKent.info
PostPosted: Dec Sat 02, 2017 4:37 pm
Thanks for confirming what my meter was telling me. At first I thought it was a funky resistor until I put leads to it and got no reading
It may be the source of a ticking I am trying to track down At the very least it is part of the circuit that's ticking because when I pushed on it with the tip of a paint brush the ticking went away and now with one end removed the ticking is not there anymore.
Thanks.
PostPosted: Dec Sat 02, 2017 6:57 pm
If you put a x10 scope probe on one or the other side of it what sort of signal is present on the part, I would wonder. Then for bonus points, nudge it with your stick. Does it change the trace on the scope? Could be that it's a part on the edge of failure, or perhaps there's just a cyclical spike at this point in the circuit that's causing the cap to chirp in a sort of piezoelectric manner.
- Scott
PostPosted: Dec Sat 02, 2017 10:43 pm
- Scott
Further testing this morning would indicate it's not the problem after all. Removing it from the circuit simply shifted the frequency of the problem. By adjusting the pa plate capacitor the noise came back.
