It is currently Jul Fri 20, 2018 5:19 pm
 Post subject: rogers majestic tubes model 7R561
PostPosted: Dec Wed 06, 2017 2:44 am
Hi.From left to right. Original were 1C7M NOW 1F5G/// 34M NOW 1F7G///34M NOW 1C7G///1F7M NOW 1D5GA///1F5G NOW1D7EC.
TEST ON TUBE TESTER HEATNIK IS 100%
1F7G 1st TEST GOOD AT MORE THAN 100%. I REDUCED THE PLATE TO 30 AND IT TESTED100%
2nd TESTED AGAIN OVER 100% GOOD. REDUCED PLATE TO 60 & TESTED 100%.
1C7G 1st TESTS 100% GOOD. 2nd TEST 83%
1D5GP tESTS AT 55%
1D7EG. TOTALLY BAD ON BOTH TESTS.
When I say TESTS for example:TUBE 1F7G TESTS DIFFERENTLY WITH 2 DIFFERENT CORDINATES. Why does it test at more than 100 on both cordinates?
Is tube 1D7EG the reason why none of the light up. Should I also replace ID5GP.
Help is always very much appreciated Thanks
 Post subject: Re: rogers majestic tubes model 7R561
PostPosted: Dec Wed 06, 2017 8:25 pm
Hi Cec
I sent you the schematic it is the 7R561 buty I sent it as a 7R651 MY MISTAKE IN PRINTING IT OUT.
Bruce
PostPosted: Dec Thu 07, 2017 2:02 am
Hello. Where can i order/purchase tube 1D7EG or an acceptable replacement. Help is always appreciated. Thx
