It is currently Jul Sun 22, 2018 3:17 pm
 Post subject: NEED TEST DATA FOR EM35 ON HICKOK 533A
PostPosted: Dec Wed 06, 2017 5:43 pm
Anyone have subject information. Thanks.
Bill J.
 Post subject: Re: NEED TEST DATA FOR EM35 ON HICKOK 533A
PostPosted: Dec Wed 06, 2017 8:45 pm
I'm pretty sure the EM35 will test the same way as a EM34. So, for the EM34...
Filament = 6.3
Selectors - JR-4507-0
Bias = Variable (see notes)
English = 100
Press P5
Notes
Connect two 1 Meg resistors from plate jack to pins 3 and 6, respectively, of any convenient test socket. Set Micromhos switch to English. Eye 1 closes at bias of about 30 & Eye 2 closes at about bias of 55
My note about eye tubes on Hickoks - I do not know of any Hickok tester that tests the triode section of an eye tube. This is presumably because failure of the triode is very uncommon compared to failure/weakening of the target.
Jim Cross
PostPosted: Dec Thu 07, 2017 6:33 pm
Thanks Jim.
Bill J.
