It is currently Jun Sun 24, 2018 12:10 am
 Post subject: Variable Capacitor Sealed In Oil
PostPosted: Dec Tue 19, 2017 2:41 am
I came across this variable cap at a junk sale, and was wondering if anyone had any info about it. I put a meter on it and got a reading of (30pf -> 800pf) @ 1kHz) I cannot find anything about it on Internet searches (except for a eBay listing with no information,) just looking for any type of datasheet or information about its original uses. Thank you
 Post subject: Re: Variable Capacitor Sealed In Oil
PostPosted: Dec Tue 19, 2017 1:19 pm
It probably was done for two reasons: the oil dielectric would increase the operating voltage and also increase the maximum capacity for the variable capacitor.
Where and why it was used is a mystery; although the owner of the one on eBay is planning an early retirement (a rather optimistic one in my opinion...)
Pete
PostPosted: Dec Tue 19, 2017 1:27 pm
Just about anything has a higher dielectric strength than air.....
https://en.m.wikipedia.org/wiki/Dielectric_strength
-Mark http://pixellany.com
PostPosted: Dec Tue 19, 2017 3:25 pm
Very nice! Thanks for posting the pic. Never seen anything like this.
Steve
PostPosted: Dec Tue 19, 2017 3:59 pm
Used one of these in the 1960’s in a 75 meter linear amplifier (3-572B’s). I removed it from a piece of WWII surplus equipment but unfortunately, I can’t remember what it was.
PostPosted: Dec Tue 19, 2017 5:23 pm
Thanks for the info. I am a new HAM, and was thinking of using it to build a magnetic loop antenna,
PostPosted: Dec Wed 20, 2017 8:44 am
Greetings to yavin101 and the Forum:
Reminds me of when I worked for Raytheon Electromagnetic Systems division. I wandered into the main testing floor and they had an ALQ-99 jamming pod running under test on a cart. Due to the high voltages inside the thing, the entire pod was filled with oil. It was pretty strange to see a couple of high voltage scope probes half submerged in oil due to being hooked up to something a ways under the surface.
One had to trouble-shoot it that way, however. If you tried to run it without the oil, it would flash over in a dozen places.
Jim T.
KB6GM
PostPosted: Mar Fri 09, 2018 8:42 pm
I used it to tune a homebrew long wire antenna. the wire is 256' with a coil. it works well on 80 and 40 meters. SWR of 1.1 at 7.189 MHz and 1.3 on 3.968 MHz. I still plan on building a magnetic loop antenna for 40 and 20 meters.
Users browsing this forum: calmark, Google [Bot] and 3 guests
