It is currently Jan Fri 18, 2019 12:41 pm
 Post subject: CRC CO Contact Cleaner used to clean potentiometers
PostPosted: Dec Sat 30, 2017 9:59 pm
One of my co workers gave me a can of the CRC CO Contact Cleaner wonder if anyone has used this to clean potentiometers on the old radios. I always resist cleaning them unless they are really noisy but sometimes you are stuck.
Bob
73's WA3TVH
 Post subject: Re: CRC CO Contact Cleaner used to clean potentiometers
PostPosted: Dec Sat 30, 2017 10:38 pm
A contact is not a control. Would you use oven cleaner to clean optics? Or carpet cleaner on your hands?
Use the right product.
PostPosted: Dec Sat 30, 2017 10:47 pm
Seems to be a pretty open subject I have seen a lot of differing opinions on what is safe to use. I see people advocating WD-40 which I tend not to use on anything. Do you have any recommendations, always reading to learn ;-)
Bob
73's WA3TVH
PostPosted: Dec Sat 30, 2017 11:01 pm
This stuff?
I have been using this for a while and not had any adverse affects.
Caretaker of Portable Tube Radios
PostPosted: Dec Sat 30, 2017 11:03 pm
If you don't like WD40, then at least go buy an equivalent product. In my shop, it is essential.
Controls: I never use anything except WD-40. It is not 100% successful, but it has never caused damage. About 20% of the time, I have to open up the control first. Then...if WD40 does not work, I can usually see why ..eg damage to the resistance element.
"Contact cleaner" or "electronics cleaner" are horribly ambiguous labels. If you use any of these, follow the instructions or be sure you know what is in them.
I use only 4 basic chemicals on a daily basis
Water
IPA (NOT on controls)
WD40
Singer light machine oil
Less often:
DeOxit D5-----ONLY on switch contacts.
-Mark http://pixellany.com
PostPosted: Dec Sat 30, 2017 11:06 pm
IPA? Is that used to lubricate the repairman before the job? :lol:
PostPosted: Dec Sat 30, 2017 11:09 pm
IPA is useful in a wide variety of situations....;)
PostPosted: Dec Sat 30, 2017 11:17 pm
+1... Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Dec Sat 30, 2017 11:46 pm
Same here.
WD-40 is wax (paraffin) in a solvent carrier. That's all. Nothing else.
The solvent serves to clean the control surface of grime and similar insults. When it evaporates (quite rapidly), it leaves behind a very thin layer of wax that serves as a protector.
The wax is extremely thin.
The contact pressure in the control is sufficient to push through it.
It remains on the non-contact surfaces to protect them from corrosion etc.
- Leigh
73 de W3NLB
http://www.AtwaterKent.info
PostPosted: Dec Sat 30, 2017 11:54 pm
WOW, thanks for all the replies. Here is the thing. I have a bunch of different Deoxit products all the them bill themselves as a "Contact Cleaner" and the more you read the less clear to me which ones are really safe on pots. I am also confused on the WD-40, is this the stuff that has been around for ever (I have several cans of that stuff) or is it the new products they have come out with. As far as the CRC CO this is stuff we use on the electronics where I work they use it on everything and we have a lot of different types of manufacturing equipment so of the stuff is 50+ years old and some is modern. Never heard of any issues but not a lot of call to clean pots (I am sure).
Bob
73's WA3TVH
PostPosted: Dec Sat 30, 2017 11:59 pm
Hi Bob,
I think the original DeOxit is now the D5 version that Mark mentioned earlier.
That's what I use for rotary switch contacts.
I was not aware of other versions of WD-40.
I buy the blue spray cans from Lowe's etc.
BikeNEPA wrote:
As far as the CRC CO this is stuff we use on the electronics where I work they use it on everything and we have a lot of different types of manufacturing equipment so of the stuff is 50+ years old and some is modern. Never heard of any issues but not a lot of call to clean pots.
I service a lot of industrial machinery. Very different from radios.
Manufacturing equipment was designed and built to last 100 years.
One significant point is the history of use of a product for a particular purpose.
I've been using WD-40 for well over 50 years without a problem. We have no such historical usage records for modern products because such records don't exist.
- Leigh
73 de W3NLB
PostPosted: Dec Sun 31, 2017 12:20 am
Leigh wrote:
Hi Bob,
- Leigh
I work in IT for a paper company, we have a lot of vintage stuff for sure, some of the stuff was made back in the late 60s and it is still going. Some of the stuff was around when I got into the field back in 1977 and it is still running critical applications. As far as hardware some of the paper machines are pushing 70+ years, modern PLCs and controls but still very old technology. Thanks for your input, I read your posts often.
Bob
73's WA3TVH
PostPosted: Dec Sun 31, 2017 12:47 am
Dog Fish makes some killer IPAs!
Bob
73's WA3TVH
PostPosted: Dec Sun 31, 2017 12:53 am
They have a contact cleaner, evaporates very quickly, I like it. This Amazon listing also show many other specialist types at the bottom of the page.
https://www.amazon.com/WD-40-Specialist ... ct+cleaner
PostPosted: Dec Sun 31, 2017 1:49 am
I gave the regular WD-40 a try on a scratchy volume control and it seems to have done the trick. Never used WD-40 on anything electronic before. I found the WD-40 Specialist on Ebay for $8 with free shipping, just ordered a can. I knew they branched out with their product line. They now even make products for care of a bicycle..
Bob
73's WA3TVH
PostPosted: Jan Thu 04, 2018 5:03 am
You can always Google the product name along with 'MSDS'.
That gives you the ingredients and proportions, For example, some clean only, while others clean and lubricate. But a volume pot is a delicate device, ask me how I know. :(
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Jan Thu 04, 2018 9:34 pm
I looked up the MSDS for WD-40 Specialist Electrical Contact Cleaner. As I interpret it, it is essentially alcohol and hexane in a propellant.
PostPosted: Jan Thu 11, 2018 6:19 am
I use Deoxit D5 on pots followed by Preservit, which is now called Deoxit P I think. I have used WD40 in the past. On the volume control on my stereo preamp, WD40 lasts about a year before having to be reapplied. The two Deoxit products together last about 3 to 4 years before having to be redone. Straight contact cleaner is good for a few months.
PostPosted: Jan Thu 11, 2018 6:31 am
$8 is a lot of money for spray alcohol. It may work well for the outside of a control but I wouldn't trust it for cleaning the conductive carbon surface.
PostPosted: Jan Thu 11, 2018 5:26 pm
Controls.....alcohol.....NO
Controls......contact cleaner......NO
Specifically for D5......has anyone ever seen words from the mfg suggesting that it should be used on controls?
