It is currently Feb Fri 22, 2019 1:23 am
 Post subject: Battery Cross Reference
PostPosted: Jan Fri 05, 2018 4:52 am
I need an Eveready 1016 and a 412. The 1016 is 1.5V and the 412 is 22.5V. Need a cross reference to a modern part number. Hoping someone has an older catalog with a cross reference table.
Thank you,
Dale
http://www.dalesantiqueradio.com/
 Post subject: Re: Battery Cross Reference - Pls move to Parts
PostPosted: Jan Fri 05, 2018 10:08 pm
Eveready 412 is a 22.5V battery commonly used in hearing aids and early transistor radios like the Regency TR-1. Exell is the only company currently producing a compatible substitute, product number is 412A. However, they retail for about $25 a piece and the physical dimensions may be slightly larger. A more affordable option would be to use a dual holder for A23 batteries which would be 24 volts in a slightly smaller form factor. The extra 1.5V will not harm anything.
I should add that there is a Chinese made 22.5v battery of the same size that turns up on eBay from time to time for about $10-15 a piece, however the quality is suspect based on the reviews.
Eveready 1016 cross-references to a 3V battery, Do you mean Eveready 1015? This would be a 1.5V A battery the same size as a modern AA.
Caretaker of Portable Tube Radios
PostPosted: Jan Sat 06, 2018 6:34 am
What is it you are powering that you need those particular batteries for?
PostPosted: Jan Sun 07, 2018 3:02 am
Early hearing aid with subminiature tubes would be my guess. A number of them used this particular battery arrangement. Be interesting if it was something else though...
PostPosted: Jan Thu 11, 2018 2:57 pm
The very rare Belmont Boulevard pocket radio.
Dale
PostPosted: Jan Thu 11, 2018 9:34 pm
Now, that is interesting! Those don't turn up too often. I've seen photographs of the chassis, it's quite a cramped contraption. Two AA were indeed used for the filament supply and a dual A23 holder should easily fit in there.
PostPosted: Jan Thu 11, 2018 11:31 pm
I'm impressed, that's a VERY hard to get radio! Please post a pic of it, esp the inside. I think Hunter's suggestion of a dual A23 holder might be your best bet, and the batteries are dirt cheap if you buy from eBay Chinese sellers.
Users browsing this forum: atwaterkent1, Barry H Bennett and 4 guests
