It is currently Sep Thu 20, 2018 5:38 am
 Post subject: philco 90 45 tube chassis. speaker type to get?
PostPosted: Dec Sun 31, 2017 7:12 pm
Have looked on ebay for speakers, absolutely nothing. I can get one for a model 90 console but I think its for a console only and has 3 wires which isnt for push pull 45 tubes, but has a 3200 ohm field coil. So far I think my chassis is missing the filter choke under the chassis and a speaker. Can I make the single ended speaker work if I add the extra wire and transformer? Chassis stamped number is 110250. I thought I would just clean up the chassis and use it like the E H scott radios with no cabinet. I could swipe one out of my not repaired model 20 radios but I think those are also not working with blown windings.
 Post subject: Re: philco 90 45 tube chassis. speaker type to get?
PostPosted: Dec Sun 31, 2017 7:26 pm
Yes, what you are suggesting should work, provided you replace the SE output transformer on the "new" speaker with a push-pull type that is of the correct primary impedance for the 45 tubes. Outer ends of the primary go to each plate of the 45 tubes; center tap goes to B+.
Output impedance is a bit of a gamble but will probably operate OK even if there is a slight mismatch... most of these early 1930s speakers used low impedance voice coils (a couple of ohms).
Speaker field matching is also important. Using a speaker with a very different field impedance from that the radio was designed for can result in incorrect B+ and bias voltages, or a burned-out field coil.
The missing filter choke coil can be replaced with a power resistor, with a much larger cap on the "downstream" end of the choke than what was originally specified, to minimize hum.
PostPosted: Dec Sun 31, 2017 7:43 pm
the rca tube data sheet has fixed bias and self bias for load. not sure which one to use but I would guess 5060 ohms for primary transformer?
PostPosted: Dec Sun 31, 2017 8:52 pm
All Philco speakers 1935 four page pdf 757kB
https://dropbox.com/s/hnvhfw5ylc5l22r/A ... 5.pdf?dl=1
Too expensive + the 300 Ohms doesn't sound right?
https://www.ebay.com/sch/i.html?_from=R ... 6&_sacat=0
PostPosted: Dec Sun 31, 2017 10:28 pm
Philco 90 version with push-pull 45 tube output uses fixed bias. 5K ohms is about right for output transformer impedance for these tubes in this configuration.
PostPosted: Jan Mon 01, 2018 5:00 am
trying to grasp fixed and self bias. Read in another thread that the stancor 125e would work? Its 15 watts, but 45 tubes can output 18 watts. I wonder if theres a stronger one out there
PostPosted: Jan Mon 01, 2018 5:30 am
Fixed bias has a negative voltage applied the control grid(s) of the output tube(s). Usually developed thru a resistor from the center tap of the hv winding of the power transformer to chassis ground.
Self bias devolopes negative voltage on the control grid from a resistor it the cathode or filament center tap on directly heated tubes powering the output stage.
Terry
PostPosted: Jan Mon 01, 2018 6:13 am
300 ohms??? extremely shorted or missing a zero?? I was thinking about getting the one from same seller for 125 but dont know of any sources cheaper. Also cant tell if thats 3 or a 4 wire one
PostPosted: Jan Mon 01, 2018 3:15 pm
You could place a WTB ad in the classified section here at arf.
It gets a lot of traffic.
Notes on (the more readily available) model 20 speaker adaptation...
http://web.archive.org/web/201603181600 ... peaker.htm
Also... See fully notated schematic for model 90 with 45 output tubes.
It's just a pity that off-the-shelf replacements can't be purchased in 2018 as those old Philco cones (like me) must be pretty stiff by now... :)
oh... the 300Ω in the ebay listing may be his reading of the output transformer's primary resistance.
PostPosted: Jan Mon 01, 2018 4:27 pm
havnt even seen model 20 speakers on ebay in a long time. Yes I have read about the model 20 adaptation years ago but dont remember much.
Not sure I remember how to post a wanted ad on arf or where its at, might try that.
Last edited by quartermilecamel on Jan Mon 01, 2018 4:41 pm, edited 1 time in total.
PostPosted: Jan Mon 01, 2018 4:32 pm
just read the speaker link. It describes the change from model 20 to model 90 but single ended application.
PostPosted: Jan Mon 01, 2018 5:35 pm
The Philco models 20,21 and 90 w/2 #45 tubes all use the same spkr. All are designed for push/pull triode output tubes. The field coils are rated @40ma. These are known as Philco K style spkrs (K and K1).
The model 70 uses a K speaker too and the field coil is the same as the 20,21,and 90 but the transformer is different because the 70 has one output tube a #47. The plate load impedance of the 47 is about twice what the 45 is. This is why you can use the 20,21 and 90 w/2 #45 tubes by use the whole primary connected to the 47.
In order to use the model 70 spkr you'll need to change the output transformer to one that matches a pair of 45's (also known as push/pull) @ 5000 ohms to about 1.5 ohms (voice coil).
Philco in the mid '30s had a number of sets at used a later style K speaker and also used push/pull triode connected 42's in what they dubbed as their super class A output. Some of the model 16b/116b used this set up. When the pentode tube is wired as a triode it lowers the plate load impedance so to be a good match for your set.
If you go the the Philco Phorum there is a downloadable list of the specs for Philco speakers from the late '20s -late '30s or so.
GL
Terry
PostPosted: Jan Mon 01, 2018 7:44 pm
I have 2 model 20 speakers. both of which I think have issues but not sure about testing them yet...........looking for the pin out diagram. I have one model 20 chassis and case which is not too bad. Other model 20 case is fair but its been 15 years and I dont even remember if I have a chassis for that one. One measures 3050 across the 2 large pins. Other one has .210k and .430k from small pin to the pins on both sides of it. couldnt detect a field coil read out on that plug at all
PostPosted: Jan Mon 01, 2018 11:11 pm
I keep seeing refferences to s e, what is that when looking at speaker wiring?
ad placed for 90 or 20 speaker will see if I even did it right. s e Im guessing is secondary transformer
Users browsing this forum: db gain and 4 guests
