It is currently Jun Sun 24, 2018 12:10 am
Post New Topic Post Reply  [ 32 posts ]  Go to page Previous  1, 2
 Post subject: Re: Oddball screw
PostPosted: Mar Thu 01, 2018 4:41 am
I use a lot of #4-40 screws in building small projects. It's a very common size. However, I have a small stash of #4-36 that my father got for something or other. McMaster-Carr doesn't even carry them! Now that's a <ahem> 'screwy' size! Never had a use for them, just like the bronze roofing nails I inherited.
― R. A. Heinlein
PostPosted: Mar Thu 01, 2018 2:02 pm
pixellany wrote:
Don Cavey wrote:
Thanks Mark, I just ordered three different "odd" size taps that I didn't have.
He who dies with th most tools wins......;)
Hear, hear! Good thought.
PostPosted: Mar Thu 01, 2018 2:46 pm
pixellany wrote:
How many know of----or have used---all these sizes ...
I have encountered all of them. Another seldom-seen thread is 4-36. I use a lot of 4-40, it is really quite common. I stock a lot of 4-40 as well as a decent selection of 2-56, 3-48, and 4-36.
PostPosted: Mar Thu 01, 2018 4:27 pm
I use 0-80 frequently here in the microwave business and typically use a pin vise to hold the tap -- main thing I have found is to go slow - back that tap out and clean the hole and tap every 1/4 to 1/2 turn and it usually goes pretty well --- for aluminum use alcohol as a fluid -- brass probably same not sure on that one -
Recommended tap drill for 0-80 is .0469 dia I usually find going the next size larger makes the tapping go easier yet still gives good retention - try using an .052 dia in a scrap piece first and see how that works for you --
For what its worth
Griz
PostPosted: Mar Thu 01, 2018 7:10 pm
I like the idea of a pin vise, but I think my tap is a bit big for one.
Perhaps its body is good enough as a handle?
PostPosted: Mar Thu 01, 2018 8:59 pm
Find a small diameter radio knob. If you can find one with 1/8 inch shaft, that's best,
otherwise you'll need to make a bushing.
Setscrew on the knob holds the tap.
Best knob diameter for 0-80 is around a half inch.
I use knobs on all my small taps, up to around 8-32 or so.
The tap you show there is a two flute gun tap, the chips are pushed out the front. They
work best on through holes, but if you leave a deep enough blind hole (leaving a place
for the chips to pile up) they're good too.
Do NOT stop and reverse the tap periodically they way you would do with a regular multiflute
hand tap. Don't stop, keep on going.
PostPosted: Mar Fri 02, 2018 12:43 am
4-40 yes lots
and 2-56 once in a while, I think, ... sounds familiar
and sometimes 3-48
PostPosted: Mar Fri 02, 2018 12:46 am
ok, maybe I should find a different tap as this will be a blind hole. A real problem if the tap would break.
I love the idea of using a knob.
PostPosted: Mar Fri 02, 2018 1:25 am
Hi Steve,
What material are you tapping?
PostPosted: Mar Sat 03, 2018 5:20 am
For a blind hole you need at least two taps. Start tapping with a taper tap:
Then use a bottoming tap:
I have a few sets of larger size taps like 1/4-20 with three taps: A tapered tap, a tap with a smaller tapered area and a bottom tap.
― R. A. Heinlein
PostPosted: Mar Sat 03, 2018 11:30 pm
UNF 10-32 and 5mm are close. I had a 77 VW, attached the (optional) right side mirror with 10-32 flatheads (they fit fine) even though they were a 5 mm thread. The reverse will bind after a few threads. The big can electrolytic caps came with either size - use the wrong screw and it might SEEM tight without quite bottoming on the terminals. At my last job, some products were all metric, others all English H/W. Metric hardware was all color coded blue for easy identification.
PostPosted: Mar Sat 03, 2018 11:43 pm
I no longer deal with metric hardware at work as we no longer use reel-to-reel tape decks, and many popular brands of those were made overseas. Some low-power radio transmitters are made overseas, but none of my clients have those.
Dale H. Cook, Radio Contract Engineer, Roanoke/Lynchburg, VA
http://plymouthcolony.net/starcityeng/index.html
Users browsing this forum: calmark, Google [Bot] and 4 guests
