It is currently Jun Tue 19, 2018 3:11 pm
 Post subject: Need sub help- again
PostPosted: Mar Wed 14, 2018 3:39 pm
I just acquired a Silvertone 4485 that has a 6N6 as an output tube. What, if any, tube can I use as a substitute?
 Post subject: Re: Need sub help- again
PostPosted: Mar Wed 14, 2018 3:46 pm
A quick search of Ebay turns up many 6N6G tubes. No need for a sub.
ex nihilo nihil fit
PostPosted: Mar Wed 14, 2018 4:00 pm
Well, I can get one from my radio club on Saturday. I was just working on it today and wanted to see if there was a possibility of getting it to play.
PostPosted: Mar Wed 14, 2018 4:27 pm
6AB6G
ex nihilo nihil fit
PostPosted: Mar Wed 14, 2018 6:28 pm
One good place for subs:
http://www.nj7p.org/Tubes/SQL/Tube_query.php?Type=6N6G
Note that I had to enter 6N6G
Don't spend a lot of calories on this--Bob Dobush has 6N6s for $7 used / $12 new. (6AB6 is a different story--2 of my suppliers don't list it--I found one new one for $35)
-Mark http://pixellany.com
PostPosted: Mar Wed 14, 2018 6:34 pm
Use 6V6, 6K6 or 6F6 tubes. When you do this lift connection to pin #8 and add a 470 ohm resistor in series with this wire. Best if you also connect a 10 - 25mf @ 50 volt cap across the resistor. You can use the radio with any of these tubes if you don't have a 6N6.
Advantage of 6N6, didn't require the above bias components.
Users browsing this forum: madRad45 and 5 guests
cron
