| Author |
N7ZAL
Post subject: Physics question, need some help. Posted: Aug Sun 05, 2012 5:25 pm |
| Member |
Joined: Jul Wed 21, 2010 11:04 pm Posts: 2438 Location: Roaming the West
I'm writing a book and have a fire scene that I'm not sure how it should evolve.
There is a small (few feet wide, few feet tall, few feet deep) steel safe on the second story of a wooden saloon. Inside the safe are some cloth cotton pouches filled with gold dust, and some loose papers. The building quickly burns down and the safe is in the rubble. Gold melts at 1947F, steel melts at 2600F, paper burns at 480F, and cotton burns at 410F. The safe is sealed tight enough that air can't get inside.
So, the questions are: Will the gold dust fuse together? Will the cotton pouches burn? Will the papers burn?
Appreciate any thoughts...
_________________ LAter, 73's Bill N7ZAL http://www.westernwoodartist.com http://www.southwestwoodcrafts.com
| Top |
RadioNut39
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 5:34 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5011 Location: The Great Pacific Northwest
N7ZAL wrote: ...Inside the safe are some cloth cotton pouches filled with gold dust, and some loose papers. The building quickly burns down and the safe is in the rubble. Gold melts at 1947F, steel melts at 2600F, paper burns at 480F, and cotton burns at 410F. The safe is sealed tight enough that air can't get inside.
Appreciate any thoughts... I believe there would be only scorching of the paper and cotton, as fire needs oxygen. As to whether the gold dust would melt and fuse would depend on the Safe's Temperature Rating
_________________ " See the World...That's What it's For...
Understanding...Nothing More."
| Top |
Tony Wells
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 5:37 pm |
| Member |
Joined: Oct Sun 18, 2009 5:38 am Posts: 3284 Location: Tyler, Texas 75707-4212
Typical house burns around 1100° f, so the metals won't melt. There is enough air already in the safe to burn the cloth and paper. HOWEVER, if the safe is insulated well enough, only time will be the main factor in the cloth and paper. A simple steel plate safe, like the old days would very likely allow the inside temp to climb enough to get the paper and cloth. A modern safe may be rated for 2 hours, and paper is, well....SAFE http://www.firesciencecolleges.com/blog ... ouse-fire/
_________________ I'm right 97% of the time. Who cares about the other 4%!
| Top |
N7ZAL
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 5:38 pm |
| Member |
Quote: I believe there would be only scorching of the paper and cotton, as fire needs oxygen. As to whether the gold dust would melt and fuse would depend on the Safe's Temperature Rating  Scorched, but readable? I have no idea what a temperature rating on the safe would be. It was built in the 1870's.
| Top |
RadioNut39
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 5:44 pm |
| Member |
N7ZAL wrote: Quote: I believe there would be only scorching of the paper and cotton, as fire needs oxygen. As to whether the gold dust would melt and fuse would depend on the Safe's Temperature Rating  Scorched, but readable? I have no idea what a temperature rating on the safe would be. It was built in the 1870's. Readable? Possibly. Re; Safe: I thought this was hypothetical? SEE: http://www.klsecurity.com/ul_fire_rating.htm "For example, if the temperature inside a safe or file exceeds 350°F, it will fail the UL test for paper rated products." However, UL wasn't Founded until 1896.
| Top |
N7ZAL
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 5:50 pm |
| Member |
Thanks Tony. I was using a fire temperature of 1832F which is on the high side, so that means the paper and cloth would burn...based on your input. I'll have to do some safe research now/ Quote: I thought this was hypothetical? Yes it is, but I need to write as accurately as I can.
| Top |
RadioNut39
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 6:01 pm |
| Member |
Tony Wells wrote: There is enough air already in the safe to burn the cloth and paper. Wouldn't One need to know the size-interior cubic feet/inches? in order to calculate amount of oxygen? ...and how much paper? I read once about a safe that fell thru the second and first floors, landing in the basement. It's contents survived even though the extent of the Fire had exceeded the safe's 'Safe' Temp. Rating @ a longer time.
| Top |
Nick D.
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 6:05 pm |
| Member |
Joined: Jun Wed 01, 2011 9:05 am Posts: 6790 Location: "Amish Country", PA
The last question... how long will the fire burn? 19th centuy safes may have walls exceeding 4". If you had a 1 sqft 4" thick slab of iron and put a fire underneath it, it would be a long time (hours) before you couldn't touch the top. That leads me to another issue... the time that has to elapse between the fire burning out and the safe being cool enough to open. It would take at least a couple hours. If you want to research, you cannot use any current data for safes. These old iron boxes are entirely different animals. It's not unusual to see the old ones identified by tonnage... 1 ton... 2 tons... 5 tons... etc.  Here's something else to think about, though irrelevant - there have been several cases where an old refrigerator was recovered from a house fire and was found to still be cool inside.
_________________ Majestic - Crosley - Zenith ~CONSOLE FREAK~ Philco - American Bosch - RCA
| Top |
RadioNut39
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 6:09 pm |
| Member |
That's SOOO funny...I almost added to the bottom of my post: "Don't worry, Nick will be here any minute now to straighten us all out..."
| Top |
N7ZAL
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 6:11 pm |
| Member |
| Top |
Nick D.
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 6:15 pm |
| Member |
Here's one from "The Antique Safe Collector" 3,200lb (~1.5 tonnes) Rated as dynamite proof.
| Top |
N7ZAL
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 6:32 pm |
| Member |
| Top |
radiotechnician
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 7:07 pm |
Joined: Sep Thu 23, 2010 6:37 am Posts: 4081 Location: Powell River BC
The building burned quickly-heat and gasses straight up- safe fell to rubble where cool updraught originated from and just rested in the glowing embers.
If the building burned quickly, it was because is wasn't built with enough fuel, otherwise the safe would not have fallen through.
| Top |
N7ZAL
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 7:14 pm |
| Member |
Quote: If the building burned quickly, it was because is wasn't built with enough fuel, otherwise the safe would not have fallen through. Basically a frame structure, but a lot of kerosene lanterns and such, plus some gunpowder. Figure the insulation was sawdust and the floors were wood.
| Top |
Dennis H.
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 7:28 pm |
Joined: Aug Mon 17, 2009 4:11 pm Posts: 1760 Location: DFW Texas
In 1870 wood construction would burn very rapidly unless built of full logs. Probably little or no fire blocking between floors so fire that starts on the lower floor would have raced up the walls and into the attic and anything heavy would have fallen through the floor very soon. No fireproof materials etc. unless this was a very well constructed building.
I don't think the contents of the safe would have been damaged in any way. I was a vol. fireman and was Assistant Chief and I've been to enough building fires to believe in my answer.
_________________ The lucky ones realize the "Good Ole Days" while they are still in them! AA5LP
| Top |
radiotechnician
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 7:40 pm |
Sawdust doesn't burn well at all. If gets shaken up in a fire, it sort of explodes, other wise it just glows on the surface. like punkwood. I worked in a power plant that burned hog fuel and needed thousands of HP of draught to get any heat out of fuel.
Everything was alight, to some extent with sawdust, and the biggest mistake, (done that) is to try and get the burning dust off our wire trays with a fire hose.
| Top |
N7ZAL
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 7:41 pm |
| Member |
Thanks Dennis. The construction would have been pit sawed lumber and shoddy construction, compared to today. It was shortly after 1876 that a few saw mills were constructed for the mining camp. So I think with a fire proof/resistant safe of the time, the type of fire, and your experience gives me confidence that the contents would be OK.
| Top |
N7ZAL
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 7:43 pm |
| Member |
| Top |
Nick D.
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 7:58 pm |
| Member |
Oh yes. In any kind of moderate humidity, it's like you're (trying to) burn wet wood. At any rate... it tends to explode (moderately) rather than burn. Clouds of flour in a fire can explode to the point of causing structural damage, however.
| Top |
N7ZAL
Post subject: Re: Physics question, need some help. Posted: Aug Sun 05, 2012 8:04 pm |
| Member |
| Top |
Users browsing this forum: Colin A., Google Adsense [Bot] and 8 guests |
