It is currently May Sat 25, 2013 9:02 pm
 Post subject: Just bought Sony 6700
PostPosted: Apr Fri 20, 2012 5:35 pm
Hi Everyone! I just bought a Sony 6700 semi portable with a broken whip antenna. Should I replace with a generic or try to solder an extension to exsisting first thee sections? Thanks in advance marc
 Post subject: Re: Just bought Sony 6700
PostPosted: Apr Fri 20, 2012 5:54 pm
Inactive
Soldering is only wishful thinking that it will be good as new. You'd have to grind off the chrome and get it down to the brass base. Find a generic antenna. How long is the present antenna??
PostPosted: Apr Fri 20, 2012 6:15 pm
If you place a piece of brass rod inside the two broken pieces it should hold up very well. About an inch or so long.
Dan
Users browsing this forum: chaz, Chris Props, Don_S, Philco Fan, stevebyan, VintageTunes and 7 guests
