It is currently Jun Wed 19, 2013 12:53 am
 Post subject: TROUBLESHOOTING A BATHROOM SCALE
PostPosted: May Fri 04, 2012 8:25 pm
I check my weight each morning on an old inexpensive Counselor
floor model digital scale. I was surprised a few days ago to see
that in only 24 hours I had lost 84 pounds. I immediately re-weighed
and was mildly relieved to realize that I had actually lost only 71 pounds.
For some reason I don't believe the accuracy of this scale.
But before replacing the 9v battery (that would be too easy), I'm
trying to decide whether the problem is more apt to be battery,
mechanical or something else. Any ideas?
(Can you tell that I'm anxious to take this thing apart?)
 Post subject: Re: TROUBLESHOOTING A BATHROOM SCALE
PostPosted: May Fri 04, 2012 8:57 pm
Have you replaced all of the caps and checked the B+? :lol:
PostPosted: May Fri 04, 2012 9:04 pm
Nor would I...but I have to ask where did you get that scale? Weight Watchers or Jenny Craig?
I know...My bad :twisted:
Ken
P.S. Impressive weight loss either way. Hopefully you didn't loose it in 24 hours.Yikes
Best
Ken
PostPosted: May Fri 04, 2012 10:39 pm
Lol.
Other than replacing the (precious few) caps in a digital scale, there's NOTHING you can do. The heart of the scale is an electromechanical transducer that converts physical pressure into electrical resistance. You can't repair it.
PostPosted: May Sat 05, 2012 12:50 am
Make sure you have not moved the pound/kilo switch, if it has one....
PostPosted: May Sat 05, 2012 1:01 am
My scale was acting up also. I thought I weighed too much so I took my shoes off and held them in may hand. I still weighed too much! Thankfully, it's under warranty :P
PostPosted: May Sat 05, 2012 1:21 am
Have had the same problem. With me it it is not being able to see the numbers or having one to many. Sometimes a combination of all above
Stan Ski
PostPosted: May Sat 05, 2012 7:49 am
a weak battery can cause off the wall readings.. spend 1-2.00 to replace the battery, then concern yourself with potential issues. Now most digital scales have a 3 volt lithium battery in them, like a 2025 or 2032 and are LCD rather then LED.. which makes them twice as reliable as older models.
BEN K. Always enjoying the sound of a tube radio warming up... and i say phooey on solid state! LOL
PostPosted: May Sat 05, 2012 12:30 pm
Troubleshooting a scale? I'd rather just shoot mine.
People who try to pretend they are superior make it so much harder on those of us who really are.
PostPosted: May Sat 05, 2012 1:24 pm
You'd have to use a pretty big barrel and a fair bit of wadding.
As for the original question:
In a word, battery. Then, if it still behaves poorly, trash. Welcome to the disposable age. I'm with Nick on this one. Some are piezo sensors. There's pretty much no practical way of fixing a crushed piezo. If that's what's wrong with it, perhaps you're not loosing weight after all! :shock:
PostPosted: May Sat 05, 2012 4:32 pm
Thank you for your replies.
This morning the scale read 179, which I think is close
to accurate. If the goofy readings continue, I'll try a new
battery. If that's no cure then I'll dump it.
I found a receipt for the thing dated 17 July 1990. So
it's really not that old. Or is it? (I think there are a few
things in our refrigerator that old.)
PostPosted: May Sun 06, 2012 2:59 am
Remind me not to eat dinner at your house :shock:
PostPosted: May Sun 06, 2012 5:23 am
At what time did this happen? Gravity's stronger in the afternoon, ya know.
-Ed
(thought that was pretty much common knowledge, even skunked ol' Nick on that one!)
PostPosted: May Sun 06, 2012 7:58 pm
My Grandson (the one in the avatar) is age 2 now and a few weeks ago he toddled into the bathroom of my Daughters house. He was laughing and having a good time when he suddenly got quiet, that's the time to investigate. She found him standing on the scales and the display was stuck on EEE. We've removed and replaced the battery and everything we could think of but it still persists with EEE. He has also managed to change the onscreen display on our TV to French.
If the facts don't fit the theory, change the facts...Albert Einstein
KAØSCR
PostPosted: May Sun 06, 2012 8:40 pm
Randy,
Is your grandson still under warranty?
PostPosted: May Mon 07, 2012 3:10 am
Don Fare wrote:
Randy,
No warranty, they forgot to send in the warranty card. He's grown quite
a bit since the avatar picture was taken.
KAØSCR
PostPosted: May Mon 07, 2012 3:22 am
Nice looking boy !
Future engineer :wink:
LAter, 73's
Bill N7ZAL
http://www.westernwoodartist.com
http://www.southwestwoodcrafts.com
PostPosted: May Mon 07, 2012 3:45 am
EE = engineering exponent
EEE = ??????????????????
PostPosted: May Mon 07, 2012 4:04 am
Alternatively, if you preferred to shoot at them, I have some 12 ga door breaching rounds that should do the trick. :mrgreen:
Yep. Battery.
We still have some electronic scales around the house, but the only ones that get any use these days are my postal ones. Even my digital reloading scales have been replaced with a balance beam setup, for better accuracy (I tend to load rounds where there's tenths of a grain between the starting load and the max).
The wife has a nice set of 1950s doctors' scales, with the movable weights, that are the best scales we've ever had, for figuring out our own weights.
PostPosted: May Mon 07, 2012 4:47 am
Jogged my memory. Anyone remember those scales that you put a penny in ??
LAter, 73's
Bill N7ZAL
Users browsing this forum: 94marconi, Adam Vaughn, Beaconhunter, blacksmith, Carter Cook, deltysdal, Eliot Ness, fifties, kc2oso, Kevin Clark, sparkgap, Stan Ski, WB8WZK and 10 guests
