| Author |
Nick D.
Post subject: Let's Design Posted: May Sun 27, 2012 1:51 am |
| Member |
Joined: Jun Wed 01, 2011 9:05 am Posts: 6729 Location: "Amish Country", PA
I've pretty much finished this one...
| Attachments: |
_________________ Majestic - Crosley - Zenith ~CONSOLE FREAK~ Philco - American Bosch - RCA
| Top |
Nick D.
Post subject: Re: Let's Design Posted: May Sun 27, 2012 6:37 pm |
| Member |
You can tell me it's ugly!! I know it is and I don't care either - it was a 10 minute sketch!
| Top |
obbm
Post subject: Re: Let's Design Posted: May Sun 27, 2012 7:34 pm |
Joined: Jan Mon 04, 2010 2:25 am Posts: 810 Location: Finger Lakes of NY
I have a mediocre collection of clocks, some advertising clocks. I like art deco. I like the font on the face of your clock.
Bill
| Top |
radiopicker
Post subject: Re: Let's Design Posted: May Sun 27, 2012 7:46 pm |
| Member |
Joined: Aug Thu 18, 2011 4:48 am Posts: 2491 Location: Stamford, NY
I like it. How much does it cost?
_________________ Vincent
| Top |
Nick D.
Post subject: Re: Let's Design Posted: May Sun 27, 2012 11:51 pm |
| Member |
Something more wild for the Plaskon lovers
| Attachments: |
| Top |
Stan Ski
Post subject: Re: Let's Design Posted: May Mon 28, 2012 12:05 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7019 Location: Clinton Twp. Mi.
Nick D. wrote: Your turn I think you should have rounded the coroners a bit. Also a speaker might be a good thing. Unless it is behind the clock. Other than that i think it is the most beautiful thing i have ever seen Stan Ski
| Top |
Nick D.
Post subject: Re: Let's Design Posted: May Mon 28, 2012 12:46 am |
| Member |
The coroners? You say the design is so bad it died? Psst... check out the second one.
| Top |
Stan Ski
Post subject: Re: Let's Design Posted: May Mon 28, 2012 12:54 am |
| Member |
[quote="Nick D."]The coroners? You say the design is so bad it died? you said it i didn't . To many 90 degrees in it Psst... check out the second one.  [/q Stan Ski
| Top |
Nick D.
Post subject: Re: Let's Design Posted: May Mon 28, 2012 1:00 am |
| Member |
And look! Now it has a speaker. Two, in fact.
| Attachments: |
| Top |
radiotechnician
Post subject: Re: Let's Design Posted: May Mon 28, 2012 1:30 am |
Joined: Sep Thu 23, 2010 6:37 am Posts: 3933 Location: Powell River BC
Hold the presses ! Nick's design would make a very nice E-Meter.
| Top |
Eliot Ness
Post subject: Re: Let's Design Posted: May Mon 28, 2012 2:24 am |
| Member |
Joined: Jan Sun 18, 2009 1:40 am Posts: 2142 Location: Lexington, KY
| Top |
Nick D.
Post subject: Re: Let's Design Posted: May Mon 28, 2012 3:31 am |
| Member |
Second draft
| Attachments: |
| Top |
radiotechnician
Post subject: Re: Let's Design Posted: May Mon 28, 2012 7:09 am |
It is really 12 minutes past twelve ?
| Top |
Nick D.
Post subject: Re: Let's Design Posted: May Mon 28, 2012 8:00 am |
| Member |
Third draft. This is where I get sad because I don't know if it's finished or it sucks...
| Attachments: |
| Top |
Nick D.
Post subject: Re: Let's Design Posted: May Mon 28, 2012 8:03 am |
| Member |
radiotechnician wrote: It is really 12 minutes past twelve ? Since when?
| Top |
dynadude
Post subject: Re: Let's Design Posted: May Mon 28, 2012 8:28 am |
| Member |
Joined: Aug Wed 26, 2009 5:38 am Posts: 3204 Location: Chapel Hill NC USA 27514
I like both designs Nick.
Is the first example intended to be built from wood with metal accents, or would they be inlays?
_________________ Bryan at Spacekat Designs, Unique Musical Instruments
~Will work for parts~
| Top |
obbm
Post subject: Re: Let's Design Posted: May Mon 28, 2012 1:50 pm |
At twelve after twelve, the hour hand needs moved a little to the right.
Bill
| Top |
Nick D.
Post subject: Re: Let's Design Posted: May Mon 28, 2012 3:00 pm |
| Member |
obbm wrote: At twelve after twelve, the hour hand needs moved a little to the right.
Bill Funny story from college... it's the "theoretical designer's clock". The hour hand only moves on the hour, but the minute hand moves normally. It is done in drawings and models to get a crisper, cleaner look and to speed up the drawing/drafting process. Of course, there are ways around it, like actually making it 1:00, 2:00, 3:00 etc, but designers like exceptions to the rule.
| Top |
DavidS
Post subject: Re: Let's Design Posted: May Mon 28, 2012 3:28 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3559 Location: Jim Thorpe Pa
Try using the the same grey and white striped patten that you used behind the controls for the clock face instead of just white.
Also make the lettering under the knobs white and place below instead of on top .
Also maybe use peep hole style station viewer instead of the large half moon dial which takes away , at least to me , from your over all design . (like on a Westinghouse Model H126 )
_________________ The lifestyle that I have is probably neither desirable nor useful to most people.
| Top |
obbm
Post subject: Re: Let's Design Posted: May Mon 28, 2012 3:54 pm |
Quote: but designers like exceptions to the rule OK, I learned something new from this. Thanks, Bill
| Top |
