It is currently Jul Sun 22, 2018 10:44 pm
Post New Topic Post Reply  [ 71 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Alternative Theory of Gravity
PostPosted: Dec Wed 06, 2017 7:20 am
until space-time unwarpage propagated out to us.
I think I see a T-SHIRT opportunity here ..................
Personally, I put my faith in DiLithium Crystals
He who dies with the most sheer tonnage of ancient test gear, wins!
PostPosted: Dec Wed 06, 2017 7:51 am
I have a theory about Gravity that says it's getting stornger over time.
25 years ago I weighed 25 pounds less than I do now, an increase in the pull of Gravity is the only explanation I can come up with.
PostPosted: Dec Wed 06, 2017 1:50 pm
I agree. Not only that, but everything I pick up has become increasing heavy over time as well. :D
Curtis Eickerman
PostPosted: Dec Wed 06, 2017 2:11 pm
When one browses these forums, one comes across a lot of threads about capacitor replacement (many of which turn tragic). One of the common tests quoted by experienced techs on this forum is that they test old capacitors by dropping them into their trash bucket. If they make a sound upon hitting the bottom of the bucket, then they are bad.
I guess that means that if a capacitor is good, it will counteract the affects of gravity just before it reaches the bottom of the bucket. I wonder if anyone has tried that experiment to see if good capacitors store anti-gravity particles (or is it waves?).
PostPosted: Dec Wed 06, 2017 6:28 pm
I believe gravity is an invisible force field(from our perception) that's been enacted upon us by whatever entity that wishes us(humans) enslaved to planet earth. Consider it a little like geo fencing. We exist here purely on a need to know basis. 8)
PostPosted: Dec Fri 08, 2017 6:25 pm
jim rozen wrote:
"An alternative theory of gravity popped into my head the other day. I'm no physicist ..."
This is apparent.
"It's that gravity is simply a manifestation of inertia and momentum. "
Nope. It isn't. Don't quit your day job.
"At least I have something interesting and positive to contribute."
If by interesting and positive, you mean "wrong" then there you go. Contributing
incorrect science to this site in particular is certainly not positive. Gravity is a complicated
topic and I suggest you research this further.
I don't accept condescension.
PostPosted: Dec Sun 10, 2017 11:07 pm
If I understand what the OP is suggesting, then at different times of day an object would weigh different amounts. At the point of time the object is on the side of the earth facing away from the center of the universe it would be heaviest. When facing the center of the universe it would float up off the surface basically having "negative" weight. When exactly half way around, it would weigh nothing at all.
Joel Walker
Professional Thread Killer
PostPosted: Dec Mon 11, 2017 2:19 am
Based on the readings on my bathroom scale, I think that's where I want to live
PostPosted: Dec Mon 11, 2017 3:26 pm
From what I've read, there is no center of the universe.
But what if G, the universal gravitational constant, 6.674×10−11 m3⋅kg−1⋅s−2, hasn't been constant since the beginning of time? Is there any way to prove or disprove whether it has stayed constant?
Prediction is difficult, especially about the future. Niels Bohr
PostPosted: Dec Mon 11, 2017 4:25 pm
My feeble understanding is that this is one of the fundamental properties tying together the physics that is understood. Everything that we know about relative motions of celestial bodies ties back to the gravitational constant. I would state the question differently---i.e. why should we suspect that it has changed? Has Coulomb's constant changed? Has the speed of light changed?
-Mark http://pixellany.com
PostPosted: Dec Mon 11, 2017 5:19 pm
I quit reading at the first page...it's making my head hurt. :mrgreen:
RW
"Hear all; trust nothing."- Ferengi Rules of Acquisition #190
PostPosted: Dec Wed 20, 2017 12:04 pm
I think you are a bit late proposing this theory.
Albert Einstein had the same thought that there is no difference between gravity and acceleration!
PostPosted: Dec Wed 20, 2017 12:08 pm
Also a modern physicist Erik Verlinde agrees and says that gravity(as a force) does not exist.
PostPosted: Dec Sun 24, 2017 2:16 pm
In the spirit of the Holidays, Baileys, Jack Daniels Devils Cut, and HEADACHES ..... I have to ask ... relative to what ??
going back to bailey's
PostPosted: Dec Sun 24, 2017 4:20 pm
So.....do we now need to define what "force" means?
I'm not aware of anyone claiming that gravity is a force. In traditional physics, gravity can CAUSE a force, just as acceleration does.
PostPosted: Dec Sun 24, 2017 5:34 pm
So, what has changed ? :shock:
Newton devised his theory of gravity after witnessing an apple falling from a tree.jpg
Newton devised his theory of gravity after witnessing an apple falling from a tree.jpg [ 13.56 KiB | Viewed 618 times ]
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Dec Sun 24, 2017 6:22 pm
Nothing has changed!
Unless he ran into Einstein at a bar, Newton would come to the same conclusion now as he did centuries ago.
gravity is a property of nature
gravitational force is the attractive force between two objects, based on their masses
"gravity" is defined mathematically by the constant K in the equation F = K*m1*m2 / r^2, where m1 and m2 are the masses of the objects, and r is the distance between their centers.
PostPosted: Dec Mon 25, 2017 5:03 pm
Just to be contrary, gravity could be the abhorrence of matter to be divided.
And once all things are returned the original state, it will morph back into energy.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Dec Mon 25, 2017 5:11 pm
Well, there's little question that gravity is exerted by the bending of space as that has already been proven, but what actually causes this phenomenon is another matter.
PostPosted: Dec Thu 28, 2017 12:52 am
Fundamental force of nature.
Electromagnetic
Strong Nuclear
Weak Nuclear
Gravity
Post New Topic Post Reply  [ 71 posts ]  Moderator: Alan Voorhees Go to page Previous  1, 2, 3, 4  Next
Users browsing this forum: K4YDO, keith49vj3, Timothybaf and 13 guests
