It is currently Oct Sat 20, 2018 1:17 am
 Post subject: Cell Phone Antenna Question
PostPosted: Dec Wed 06, 2017 8:20 am
Our relatives on a remote lake get Verizon just fine, but our ATT is spotty. I have to go stand on the dock to check my messages and I still get connected only 50% of the time.
We visit only occasionally so I'm thinking of building a Yagi on the cheap and making a passive coupler. It's for LTE, but how do I know whether to build a 850-900 MHz or 1900 MHz antenna? I know where the tower is (8 miles away). How does one determine which frequencies are used?
 Post subject: Re: Cell Phone Antenna Question
PostPosted: Dec Thu 07, 2017 4:47 am
I wrapped a wire around my phone and connected it to my frequency counter and made a call.
I think it came up in 900 mHz range. It worked on my EIP frequency counter but not on my HP unit.
It is not unusual for different services to be spotty in different paces. In East texas Verizon works
better than ATT but at my house ATT works and Verizon doesn't. There was a company that made cell
a phone booster which was inductively coupled to the cell phone. You installed it in your car.
I think it was Wilson.
PostPosted: Dec Thu 07, 2017 7:12 am
Excellent, thanks. I was reminded that my frequency counter has a high impedance setting that will display RF at short ranges. I made a call and it registered 826 MHz.
PostPosted: Dec Fri 08, 2017 5:41 am
It works.
I made an 11 element Yagi calculated at 12.5 dB gain. The driven element is a folded dipole so it's connected to 300 ohm twin lead. At the other end of the twin lead is a duplicate folded dipole.
The cellphone antenna is on the bottom of the phone. When I position it in the second dipole perpendicular to the plane of the dipole, the meter moves up 5 -10 dB. I need to do more testing, as the fluctuations may be due to the nature of cell communications. But it does improve the signal noticeably, which was my goal. Thanks for your input.
PostPosted: Dec Fri 08, 2017 6:02 am
I am glad I could be helpful as most of the time it is me receiving the help.
I am interested in your Yagi could you post a picture or a diagram?
PostPosted: Dec Fri 08, 2017 7:15 am
It looks very much like the one pictured below, but with 11 thicker elements not 14 thin ones. The picture's complete article is here: http://bcbj.org/antennae/lte_yagi_diy.htm
I used 1/4 in aluminum rod for the parasitic elements, 3/4 in aluminum tubing for the boom. 1/8" copper grounding wire for the driven element folded dipole.
The design came from here: http://www.k7mem.com/Electronic_Noteboo ... i_vhf.html
PostPosted: Dec Fri 08, 2017 7:38 am
OK, this is gonna sound strange, but maybe not to you guys. Some years ago camping in the desert southwest in a remote area was having real trouble connecting to a cell tower at the location. On a hunch I took off my shoes and went barefoot on the slickrock. Got through OK then. Is I was or was I not antenna/ground plane, or just a coincidence? It seemed to work a couple times.
PostPosted: Dec Fri 08, 2017 5:52 pm
I don't know what you were but that is why antenna stuff is as much art and mystery as it is science.
PostPosted: Dec Fri 08, 2017 10:58 pm
Video here: https://www.youtube.com/watch?v=U1Fqzs6 ... e=youtu.be
This example shows 8 dB gain. So far, in the house, typical gain is 5-10 dB. Not bad for passive coupling.
PostPosted: Dec Sun 24, 2017 8:18 pm
UPDATE : I got a chance to test the antenna at the actual location where we were having problems. Without the antenna there is no measurable signal, below - 135 dbm, and with the antenna it's - 107 dbm which is about 1 to 2 bars. Whereas before we only had spotty reception this gives reliable reception even though it's weak, it's reliable enough for voice calls and text at all times.
The irony is that I don't need the antenna at all. I discovered WiFi calling.
PostPosted: Dec Sun 24, 2017 8:26 pm
Some cell providers will supply a local signal booster in low signal areas. That's another option.
PostPosted: Dec Sun 24, 2017 11:50 pm
Verizon is always the one to connect further away than AT-T & Sprint. The difference is how they address their towers.
Verizon uses few towers and higher power on their phones. AT-T uses more towers and less power on the phone.
PostPosted: Dec Thu 28, 2017 5:34 pm
You may be interested in this. I have bought about 10 items from these people and they are legitimate.
http://www.tmart.com/High-Gain-GSM-900M ... s2017&cvfd
Post New Topic Post Reply  [ 13 posts ]  Moderator: Alan Voorhees
Users browsing this forum: 35Z5, allied333, radioalfa, Rickey, roguethistle, Tarpawns, Todd and 11 guests
