It is currently Aug Sat 19, 2017 4:24 am
 Post subject: Just inherited a 1954 RCA....HELP!
PostPosted: Aug Fri 11, 2017 4:50 pm
I'm recently the proud owner of a 1954 RCA-Victor 21-S-522N.
Now I know nothing about televisions, but I love mid-century furniture and electronics. I've played around a little with my RCA 19k radio, but I feel in over my head with this one. Hence why I'm posting here since you guys seem to be the experts. (Sorry if this is posted in the wrong place)
It's in amazing shape cosmetically. Looks like it was just brought home from the store.
Being an RCA, it has a port for an RCA cord and works beautifully for playing music from my phone.
I decided to try and get the picture up and running, so I ordered one of these:
:Amazon: WINEGARD-TV-2900-82-Channel-Weatherproof-Transformer
and used this in conjunction with an RF modulator to see if I could hook up my old Roku. I fiddled with all the adjustments, but just couldn't get a decent picture, so I assume something is damaged internally.
My first question for you guys is if I've done anything wrong with trying to setup the Roku. Do I need a different transformer or RF modulator?
Also, are there any adjustments I can make that I don't know about (being a complete noob with vintage TVs)?
Secondly if there is something wrong with the internals (which I'm 80% certain) is this a symptom of something specific? I may have to find someone locally who knows about these, but don't know where to look yet.
It should be noted that I haven't opened it up or touched anything in anyway. I'm 100% sure that this is all original and has never been tampered with except for probably getting serviced in the 50s or 60s.
Here is an album showing the television set, model, and the picture I've managed to get out of it. Any advice, tips, or help would be greatly appreciated!
I'm really hoping I don't get addicted to TVs now, but this is all I can think about for several days now :roll:
I had an imgur album with full res, but looks like I can't post it.
File comment: The TV
File comment: First time turning on
File comment: Model info
File comment: Adjustment knobs
File comment: Best picture I could get
 Post subject: Re: Just inherited a 1954 RCA....HELP!
PostPosted: Aug Fri 11, 2017 10:24 pm
Best picture is close to right. Looks like you need to adjust horizontal hold (corrects diagonal/horizontal image roll/multiple pics).
Any TV this old with original capacitors is living on borrowed time....Running it like that is sort of like pulling a car that has been sitting in a barn for 40 years out filling the tank with gas, pop starting it and expecting the original oil, transmission fluid, brake fluid, etc to still be good for a few years of daily driving.
That said this can be a good learning experience. Tweak the hold controls till it is in sync, get a test pattern up (end credits can work as a pattern in a pinch), and establish a baseline. Then recap it a few caps at a time, checking operation every few parts (if it gets worse stop and find your mistake). The fact that it works as well as it does indicates that all the unobtainium parts still work.
I assume you have changed capacitors on tube radios before?...If not do a couple of radios first...It will give you practice in the skills you need.
You will probably want a copy of the schematic Rider's TV volumes, Sam's photofact, and Bietman's are good sources.
You may want to read as much of the forums here as you can to bone up on TV, it also may be beneficial to find an old TV service book or 3 and start reading them.
PostPosted: Aug Fri 11, 2017 10:34 pm
Thank you for the reply.
I was trying my hardest to get the horiz working, but it just wouldn't get any better than this. I could get it from really bad to about like this, but then if I kept adjusting it would go to really bad again.
I need a lot of practice changing caps, so I should find another radio to work on. At the very least, I'm sure they all need to be changed out.
I didn't even think about looking for TV service books. Thanks for the tip! I'll have to find some and glean what I can.
PostPosted: Aug Sat 12, 2017 1:30 am
That is a beautiful set and the condition is extraordinary!
Most 50's consoles are pretty blah but that is very "Mid Century" I have a similar model with the blonde face and maple cabinet.
It's almost working, some new caps will make it 100% again.
PostPosted: Aug Sat 12, 2017 3:15 am
You'll want Sams 282-13. Looks like this:
You can still order reprints online but it's best to seek out an original from eBay or our classifieds section.
I like the series and have a similar set.
PostPosted: Aug Sat 12, 2017 3:47 am
WeekendHacker wrote:
You'll want Sams 282-13...
And my experience and understanding is that the Sams scans are really terrible AND outrageously priced.
Good advice.
PostPosted: Aug Sat 12, 2017 4:21 am
If that schematic is not already in the database at the ETF Early Television Foundation, a request for it will usually result in it being scanned and added pretty quickly, and at no charge.
http://www.earlytelevision.org/tv_schem ... s_rca.html
That was a decent chassis and one that works well when restored.
PostPosted: Aug Sat 12, 2017 4:38 am
That model comes up in RadioMuseum.
Bob
Life is too short to be serious all the time.
PostPosted: Aug Sat 12, 2017 2:02 pm
Check your messages....Craig
PostPosted: Aug Sat 12, 2017 3:17 pm
Thank you so much for the replies everyone!
I've been soaking up articles and YouTube videos. Now just building up the courage to crack her open.
I've never done a full recap before, but it sounds like that's a good place to start.
How likely am I to completely eff this set over? That's what I'm most nervous of
PostPosted: Aug Sat 12, 2017 4:03 pm
The biggest "eff-over" would be to scratch, dent, or stain the cabinet. Or set it on fire. The condition of your TV is remarkable and is its primary value. I would cover it with multiple soft blankets and such the whole time it's being serviced.
CRT necks are quite fragile. Inadvertently bumping one with only moderate force can spray a million shards of razor-sharp glass bullets across a room. Replacement CRTs are getting rare. Replacement eyes and skin are still pretty unobtanium.
High voltage really hurts. "Low voltage" in these sets are significantly high current and should be considered lethal, although most of us have numbed an arm or a finger or two. If you aren't confident around electricity, this can be intimidating.
You risked an "effover" by plugging it in and powering it up cold without preliminary checks that a more experienced user would have done first. Impatience is not a virtue in this hobby.
Some among us would have you work on something a little more expendable first. The earlier advice of doing 3 or 4 AM tube radios first is good advice. There are tools you need to own to do this hobby. They are cheap and easy, individually, to find and buy, but combined may take a little while and moderate investment to obtain. And a significant investment of time to learn how to use them.
Plus side is it's a hobby that teaches you how to think and reason and troubleshoot. These skills pay off elsewhere in life.
Short answer is, "It depends". Nobody here knows how clumsy or not you might be. Or your attention span. Or how good you are with tools. Or any other experience you might have, or lack.
But if you refrain from catastrophe, you probably can't eff it up to the point that one of us couldn't undo it. Getting someone local to look at it is always difficult, as the few repairmen that still exist are few and far between these days.
Try a radio first. Revisit the question afterwards.
PostPosted: Aug Sat 12, 2017 4:12 pm
Exactly.
And when you do feel more confident in trying, we will advise you how to proceed. Since the set basically works, you would first do the most critical capacitors, including those in the power supply and around the section where the problem which is currently preventing the picture from locking in. Once that's working, you could then proceed to do the rest of them a few at a time.
PostPosted: Aug Sat 12, 2017 4:45 pm
I completely agree. With you guys.
I have a couple of radios that I've picked up along the way that are pretty expendable. I think I'm going to practice recapping and getting those up to snuff before fiddling anymore with the television.
It's so hard to be patient being this excited!
PostPosted: Aug Sat 12, 2017 7:53 pm
Seems like you were able to get pretty good contrast on the CRT and that is a big plus, replacement CRTs can be pricey and hard to find.
All good advice so far.
Look at how the construction on the radios and TV is done. When you replace parts try not to leave any more of the component leads exposed that the original part had. Many times I will insulate more of the leads than original. If you make any splices in the wiring be sure to insulate them with tubing of some sort.
Also don't add excessive wire length to parts. If you use any heavy parts like large electrolytics fasten them down somehow, don't let them just hang from the wires. Although you wouldn't be thinking about it now, sometime in the future the set will be moved around and jostled, you don't want parts to move around and short. Generally when restoring TV and radios people will prefer to use the original methods to insulate and mount components, however modern methods and material like heat-shrink tubing and plastic tie-wraps under the chassis will add to safety and reliability.
Tim
747, 465, 1230, 1471B, 2005A, 1075
C-3, SG-8, V-7A, TC-2P
LAG-27, LBO-517
5382A, 368, 260, 8024B
PostPosted: Aug Sat 12, 2017 8:21 pm
Good plan. This page has a bunch of TV restoration articles:
https://antiqueradio.org/televisions.htm
None is identical to yours, but if you skim around, you'll get a general idea what's needed to make a vintage TV safe & reliable to play.
Here are a couple more articles that may be helpful (for your radio projects as well as the TV):
https://antiqueradio.org/FirstStepsInRestoration.htm
https://antiqueradio.org/recap.htm
Phil's Old Radios
PostPosted: Aug Sun 13, 2017 5:36 am
That's a very nice set, you have. I like these style of console's. For the most part, they are compact compared to a number of other examples out there.
I didn't see a scan of this chassis' schematic on earlytelevision.org. How do you upload to their site? Surprisingly, I actually have the full Sam's for this chassis, and it's in great shape. Other than the outer folder, that protects it.
Post New Topic Post Reply  [ 16 posts ]  Moderators: 7jp4-guy, Mr. Detrola
