It is currently Jun Thu 20, 2013 8:29 am
 Post subject: 6000 volt caps sources?
PostPosted: May Wed 16, 2001 2:46 am
Hi,<P>Im new to the forum. Wheres a good place to get the 6000 volt caps used in the deflection circuits of the early tvs?<BR>I knew of a source to order from a while back but cant find it anymore.<BR>thanks<BR>Alan<P>------------------<BR>
PostPosted: May Wed 16, 2001 3:01 am
Hi Alan<P> AES catalog shows .001, ,0047 and .01 mfd @ 6000 volts, tubesandmore.com or call 480 820-541.<P> You could search past postings. Other companies were mentioned.<BR><P>------------------<BR>Norm
PostPosted: May Wed 16, 2001 4:35 am
Try <A HREF="http://www.nwlink.com/~mhannah1/surplus.htm" TARGET=_blank>http://www.nwlink.com/~mhannah1/surplus.htm</A> <P>$2.00 ea for the .0047@8000 Spragues but you better hurry, he was running low when I called a few weeks ago. <P>I can get some .001@10,000v ceramics dirt cheap at a local shop. They work great for the horiz circuit, if you need a couple just drop me an E-mail at thefiftys@aol.com<P>Eric<P><P>------------------<BR>
Post New Topic Post Reply  [ 3 posts ]  Moderators: Mr. Detrola, 7jp4-guy
