It is currently May Sat 26, 2018 6:21 pm
Post New Topic Post Reply  [ 47 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: 7" Admiral
PostPosted: Jun Sun 17, 2012 2:39 am
I only test 7JP4's in a working set.
PostPosted: Jun Sun 17, 2012 8:11 pm
Yes testing in a working set seems to be the only real option.
I tried rejuvenating one, but it had no effect.
PostPosted: Jan Mon 09, 2017 11:38 pm
I know I could start a new thread, but since this TV is directly related, I thought I would post it here.
Is that a bad idea?
Anyhow, last May I was at an auction mostly to get a Grunow radio, and I ended up purchasing this Admiral TV because it went for practically nothing.
It turns out to be an Ebony model 19A12S
Surprisingly it cleaned up well and doesn't have a single crack! How on earth it survived, I don't know.
It looks as if it may have been submerged at one point in its life as it was covered in a brownish rusty looking film.
Not sure what will be found inside.
I need to fix one of these so I can at least check other 7JP4s
PostPosted: Jan Fri 27, 2017 6:11 am
Looks like your really going to fire it up!!!!!
I got one of those for cheap but needs the fine tuning knob& channel selector knob. Haven't had it on the bench yet. Also have a Chinese grille set that I serviced a number of years ago. Like all have said easy to work on and good players for a 7"job.
https://www.flickr.com/photos/42774321@ ... otostream/
Terry
PostPosted: Jan Fri 27, 2017 2:03 pm
Yeah, maybe setting it on the range wasn't the best idea for a photo :lol:
I see these came with different speaker grill patterns. I like yours better than the waffle design of mine.
PostPosted: Jan Fri 27, 2017 8:43 pm
I think the waffle grille is the most common of the three. The Chinese and wooden model are a bit harder to come by. OBTW there are repro of the channel indicator plate your looks a little small.
GL
Terry
PostPosted: Jan Sat 28, 2017 1:06 am
Yes, I need to order a replacement channel label. Its pretty shriveled up.
Post New Topic Post Reply  [ 47 posts ]  Moderators: 7jp4-guy, Mr. Detrola Go to page Previous  1, 2, 3
Users browsing this forum: StellarTV and 4 guests
