It is currently May Wed 22, 2013 1:49 am
Post New Topic Post Reply  [ 43 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: New addition, 1947 General Electric 802 Floor Console
PostPosted: Dec Wed 28, 2011 4:17 am
All voltage chatactoristics are the same as 10BP4.
Bill Cahill
PostPosted: Dec Wed 28, 2011 10:50 pm
ketron281989 wrote:
I have a B+K CRT tester/rejuvenation, to test the CRT, there is listed the Heater voltage and adapter socket, I know about the adapter socket. Is the HTR range the same as heater voltage.
Yes. Set the control to minimum, move the switch to 4-7 volts, then turn the power on and adjust the control for 6.3 volts on the meter.
(Antique TV collecting) always seemed to me to be a fringe hobby that only weirdos did.
PostPosted: Dec Thu 29, 2011 4:54 am
Also, if the readings are low at first, let it warm up for an hour or more. These old CRTs that have been sitting round for decades can take a good long while to come back to life. Using the rejuvination feature is a bad idea. These a chance you could blow a lot of material off the cathode or burn out the filament.
I've got my fingers crossed for ya :)
PostPosted: Dec Thu 29, 2011 5:08 am
Thank you both
PostPosted: Dec Thu 29, 2011 5:10 am
Bob, also I did mention that the base is quite loose, you can see old glue residue from decades ago, I when to the auto store and bought some Permatex as recommended in your video on gluing a base to that globe tube that was missing. Would this be good for the CRT, or should I use something else. Thanks
Jon
PostPosted: Dec Thu 29, 2011 5:49 am
Yes, I've used Permatex Windshield & Glass Sealer on loose CRT bases with good results.
PostPosted: Dec Thu 29, 2011 2:58 pm
Eric H wrote:
The 10FP4 was standard equipment on early GE sets.
Hmm... I just acquired a GE 801 and it has a GE branded 10BP4 with an ion trap. Could be that they used the 10FP4 when they could and the 10BP4 when supplies ran low.
PostPosted: Dec Thu 29, 2011 8:39 pm
vts1134 that is an interesting thought. My paper label on back of the cabinet has the 10BP4, but someone crossed it off with pencil and wrote in 10FP4. I still have to test my picture tube. Did your's test good or decent? I am scared that mine will be dead.
BUT I think otherwise now. Even though does not really reinforce what the picture tube might read. I pulled out all the tubes, cleaned each and came across one that was made in Japan. I will keep it for now unless I have a USA one on hand.
My question is to all of you is when did the US start receiving Japan made vacuum tubes. This is the first time I have come across this with all 7 or 8 sets I have already cleaned in my collection.
PostPosted: Dec Thu 29, 2011 8:40 pm
Are you sure yours is an FP4? They would be aluminized.
GE only used that tube on some models, I've found. I have one bakelite GE Locomotive with original 10BP4, and, the tube chart shows that number.
Bill Cahill
PostPosted: Dec Thu 29, 2011 8:52 pm
Yeah, I think only some models and early production sets used a 10BP4. My GE 800 locomotive shows a 10BP4 while my GE 802, 806 and 810 show a 10FP4 in the tube chart.
PostPosted: Dec Thu 29, 2011 9:37 pm
I do wonder why someone crossed out the 10BP4 and put a 10FP4, a replacement? Also on the tag it says 802, Bob, does yours also say 802, from your pictures yours stated 802-DP, mine is a 802.
here is what I don't get, look to the right of 802, is this a sub model like bandersens, I don't know
PostPosted: Dec Thu 29, 2011 11:08 pm
Here's the label from mine. I suspect yours is an earlier production run with the changes penciled in. The rest appears to be identical.
PostPosted: Dec Thu 29, 2011 11:27 pm
I expect that they switched to the 10FP4 almost as soon as it became available. They would not necessarily change model numbers or wait for a new model to come out.
PostPosted: Dec Fri 30, 2011 12:03 am
So I would have to agree that my model was a earlier production run, as Tom just stated, they turned to the 10FP4 when available, and still used the earlier sticker when the 10BP4 was common. good I was curious to see why the difference.
PostPosted: Dec Fri 30, 2011 11:17 pm
In some of GE's early 50's advertising they use the term Black-Daylight Television, I wonder if this referred to an Aluminized tube or DC restoration, or both?
PostPosted: Dec Fri 30, 2011 11:21 pm
Actually, it refers to the phosphor. It was supposed to be better quality.
Bill Cahill
PostPosted: Dec Fri 30, 2011 11:40 pm
Eric H wrote:
In some of GE's early 50's advertising they use the term Black-Daylight Television...
Here's an example of those ads: http://library.duke.edu/digitalcollecti ... ss_TV0598/
"58% deeper blacks and 140% great picture range" - of course there's no mention of what they are comparing it to :wink:
PostPosted: May Fri 25, 2012 4:16 am
I know this is an old post, but I think I just bought the record changer for the original cabinet. If you are around and interested, let me know. How about a trade?
PostPosted: Sep Tue 18, 2012 12:07 am
I have the exact same unit. I am not a collector or a radio buff, but i dont want to just throw it away please let me know if you or anyone else is interested. Thanks
PostPosted: Sep Tue 18, 2012 12:33 am
Where are you located? I know people would be interested, but, without knowledge of where you are, it's hard to tell.
Bill Cahill
Post New Topic Post Reply  [ 43 posts ]  Moderators: Mr. Detrola, 7jp4-guy Go to page Previous  1, 2, 3  Next
Users browsing this forum: MOLE, philsoldradios and 4 guests
