| Author |
cwmoser
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Mar Fri 30, 2012 12:23 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3352 Location: Advance, NC USA
Doug66 wrote: I got some Spray Nine also today and sprayed my chasis too. I used a paint brush and bottle bottle brush to scrub the chasis. I just wiped it off rather than turn the hose on it. I didn't feel confident doing that. I let mine dry in the sun too.
Doug Good show Doug. Nice to have someone else working on one too. BTW, which chassis revision do you have? Mine is "W" - big old "W" stamp on the front of the chassis. Carl
| Top |
M3-SRT8
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Mar Fri 30, 2012 2:14 am |
Joined: Nov Thu 08, 2007 2:44 am Posts: 2178 Location: Worcester, Mass.
You should rinse off the Spray Nine. It leaves a residue.
Rinse it off, blow it dry, and bake it. It will be squeaky clean.
_________________ Lee
Worcester, Mass
| Top |
M3-SRT8
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Mar Fri 30, 2012 2:16 am |
cwmoser wrote: I agree, I'm going to buy 630volt axials. I too like to order from JustRadios.com - I like their Excel Spreadsheet order form. I removed the finish off the solid brass pieces and polished them today: Attachment: CabinetParts-640.jpg Brasso and Novus #2 works wonders on the Bakelite. I'm pondering whether to protect my shiny brass pieces or just let them tarnish with age. Been a busy day. Also found some Spray Nine and washed off the Chassis. Took a garden hose to it. I protected vulnerable parts with plastic and masking tape. Let it dry in the Sun. Took my air compressor and blew off moisture. I don't think I really need to bake it in the oven as it will be a couple weeks before I'll apply power to it. Carl Clear coat your brass with spray lacquer, like a semi-gloss or a gloss finish. Better yet, add your red lettering then seal it. It will be easier to fill in the red lettering first on a bare metal surface, then you can buff off the excess red so the letters are crisp. Then clear coat the whole bezel.
Worcester, Mass
| Top |
Doug66
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Mar Fri 30, 2012 2:33 am |
Joined: Mar Wed 30, 2011 5:37 am Posts: 597 Location: GA
Carl, Mine is called the Early Version. Riders list them as U,W, S,T & Early. As soon as my reconed speaker come in, I'll be able to power it up again and report the results. I am going to try Brasso on the front plate and redo the red lettering.
Doug
| Top |
hoffies too
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Mar Sat 31, 2012 3:21 am |
Joined: Dec Thu 15, 2011 4:16 pm Posts: 1090 Location: East Coast
| Top |
Doug66
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Mar Sat 31, 2012 7:53 pm |
I got some Brasso today and got the front grille shiny. How do I fill in the red lettering before I spray some clear finnish on the grill?
Doug
| Top |
cwmoser
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Mar Sat 31, 2012 9:43 pm |
| Member |
Hoffies ... nice looking GE 805. Got any tips or anything peculiar when you did your recapping? I'm going to order my Capacitors Monday. Going to stuff the Electrolytic Cans.
| Top |
cwmoser
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Mar Sat 31, 2012 9:49 pm |
| Member |
I found the best way was to get some cheap acrylic red paint at a hobby store. Brush/smear the paint across the lettering. Wait about a minute, then take a wet paper towel and wipe it off leaving the red paint down in the groves. I made a slight boo boo. I did not get all the Brasso residue off my faceplate and the lacquer finish got a little blotchy. I'm debating on whether to live with it or strip it off again. Its not bad and I think will be OK once the knobs are on. You might want to make sure the brass is clean of Brasso before you apply the red paint. Try cleaning the brass with lacquer thinner, then the red paint, then the clear lacquer spray. Don't put th lacquer on heavy as it may run. Let me know how it goes for you. Carl Doug66 wrote: I got some Brasso today and got the front grille shiny. How do I fill in the red lettering before I spray some clear finnish on the grill?
Doug
| Top |
Doug66
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Mar Sat 31, 2012 11:54 pm |
Success! I just finnished filing in the letters with red. Tomorrow, I'll shoot the grille with clear. Here is the result. Doug
| Attachments: |
| Top |
cwmoser
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Apr Sun 01, 2012 12:28 am |
| Member |
Looking good. Makes a big difference shinning up the brass. I also noted that when I cleaned the gasket, it make a big difference in appearance.
I need to place my capacitor order so I can get this thing recapped.
| Top |
Doug66
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Apr Sun 01, 2012 12:31 am |
My gasket seems to be in good shape, so I think I will leave it as is. My bakelite is very dull. I've been polishing on it with Novus off on on over the past week, but I can't seem to get it shiny like it should be. Doug
| Top |
Beaconhunter
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Apr Sun 01, 2012 3:27 am |
Joined: Nov Fri 04, 2011 3:12 am Posts: 416 Location: New York
Carl- About seleniums.... My post with good info added by Rich and Steve towards the bottom. The purpose of my post was to give people a ball park to start with, but with higher line voltages, add a little insurance. viewtopic.php?f=8&t=178716Good luck! John S.
| Top |
cwmoser
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Apr Sun 01, 2012 11:09 am |
| Member |
John, good info, thanks. I think I am going to discern a replacement circuit for replacing Selenium Rectifiers in the GE 805 - simply a circuit with a resistor in series with the 1N4007 - and come up with a value for that Resistor that future restorers can reference. What I would like to see is resource documents on various TVs such as this and a recap capacitor order listing. Can you think of any thing else we can document that would be specific to a particular TV? Just pondering.
| Top |
hoffies too
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Apr Mon 02, 2012 1:42 pm |
cwmoser wrote: Hoffies ... nice looking GE 805. Got any tips or anything peculiar when you did your recapping? I'm going to order my Capacitors Monday. Going to stuff the Electrolytic Cans.
Carl Hi Carl, The cabinet and metal trim were perfect so just a polishing was instore. I changed the electrolitics and made a resistor change in the verticle output circuit to get a full raster. I kept all the rest factory and only turn it on once a month for 15 minutes.
| Top |
cwmoser
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Apr Mon 02, 2012 9:52 pm |
| Member |
Using my old Western-Electric Printed Circuit Board stand as a Chassis Stand to make recapping easier.  Once I get those huge 60uf and 150uf Electrolytics out of there, it should free up some room to work. Looks like some electronic hacking has been going on as there is a 30uf capacitor that is not in the Schematic. Got one electrolytic can stuffed but those 150uf capacitors are blocking me from the other can. Ordered Capacitors today and ready to get going. The felt feet on the bottom - I only have 3 and the felt has outlived its life. Anyone know where they can be purchased? These are the round metal disks that you screw to the chassis through the Bakelite case and they have felt discs you insert in them. Carl
| Attachments: |
| Top |
cwmoser
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Apr Mon 02, 2012 10:21 pm |
| Member |
hoffies too wrote: Hi Carl, The cabinet and metal trim were perfect so just a polishing was instore. I changed the electrolitics and made a resistor change in the verticle output circuit to get a full raster. I kept all the rest factory and only turn it on once a month for 15 minutes. Hoffies. Good show. The more I work on these TV's the more I like the way they look - I especially like it now that the dirt is gone and there is some shine on the cabinet. The GE 805 I purchased in March was the same one I saw in Sept 2011 at the Shelby Ham Fest. Same seller at both events. Guess nobody willing to make the purchase or invest the time it takes to restore it. I've done all the cosmetics - polished/lacquered the Brass, cleaned/polished the Bakelite, cleaned chassis, knobs, CRT Gasket, obtained a missing knob -- now the fun part -- Recapping!! I'd rather be holding a Soldering Iron than scrub pad:-) Carl
| Top |
cwmoser
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Apr Mon 02, 2012 10:25 pm |
| Member |
Doug66 wrote: My gasket seems to be in good shape, so I think I will leave it as is. My bakelite is very dull. I've been polishing on it with Novus off on on over the past week, but I can't seem to get it shiny like it should be. Doug Are you using Novus #2? Follow up with Novus #1 and buff it with a clean cloth. Some folks I've read use a wax - I've read that they use Pledge furniture wax and I've read some use car wax. If you can't get the shine to come out, check with Bandersen on http://videokarma.org/forumdisplay.php?f=19 -- now he's the pro with refinishing antique TVs. Bandersen has a lot of good videos on YouTube too. On YouTube, he goes by "BandersenTV". He does some amazing work. Here is one on Bakelite: http://www.youtube.com/watch?v=V5ezGXM4ZT4Carl
| Top |
Doug66
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Apr Tue 03, 2012 1:30 am |
What I am doing iis starting with Novus 1 then finnishing with Novus 2. I'll check out Bandersen's video.
I sprayed the grille with clear today, so it's ready to be reinsalled. Doug
| Top |
Tom Schulz
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Apr Tue 03, 2012 3:11 am |
| Member |
Joined: Mar Sun 01, 2009 10:27 pm Posts: 2917 Location: Ann Arbor, MI
Doug66 wrote: What I am doing iis starting with Novus 1 then finnishing with Novus 2. I think that you are doing that backwards. Start with 2 and do the final finish with 1.
_________________ Tom
| Top |
bandersen
Post subject: Re: GE 805 Locomotive scored at CC-AWA ... Posted: Apr Tue 03, 2012 5:41 am |
Joined: May Fri 29, 2009 4:35 am Posts: 1070 Location: Chicago, IL USA
cwmoser wrote: ... If you can't get the shine to come out, check with Bandersen on ... Carl Thanks for the kind words. I think you might have been trying to link to my GE 800 restoration thread where I wet sanded the cabinet. Here it is: http://www.videokarma.org/showthread.php?t=247956I don't recommend using Novus #1 on bakelite as it leaves a film on it and can make it cloudy. Lately, I've been using Meguiar's Cleaner Wax with good results. It was recommended by Nick D. in this thread: viewtopic.php?f=7&t=170021
| Top |
Users browsing this forum: psbot [Picsearch] and 2 guests |
