| Author |
KA
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: May Tue 29, 2012 5:41 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 306 Location: Austin, Tx
Noisebox, thankyou very much for the great photos with the measurements of the antenna tuning knob. The chances of my finding this part are probably next to none, so this will greatly help in fabricating a temp replacement. Again, thank ypu for your time and your help on that.
| Top |
noisebox
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: May Tue 29, 2012 7:44 pm |
Joined: Mar Mon 02, 2009 11:48 pm Posts: 2877 Location: 97381, USA
KA wrote: Noisebox, thankyou very much for the great photos with the measurements of the antenna tuning knob. The chances of my finding this part are probably next to none, so this will greatly help in fabricating a temp replacement. Again, thank ypu for your time and your help on that. No problem! I was thinking of getting a small plastic casting kit soon. If I do I'll make you one--couldn't be that hard. Ben
| Top |
noisebox
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: May Tue 29, 2012 7:57 pm |
| Top |
noisebox
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: May Tue 29, 2012 8:33 pm |
Found out where the cap is on the schematic Another thing I learned--don't trace components from the ground end--it's rather impossible. I traced the cap from the other end back to V5--6AU6 pin 1. Confirmed the path through the resistors and their values on the schematic and it took me on the schematic to C56, a .22mf cap. Two more bumble bees and I'm done with the recap!
| Top |
cwmoser
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: May Wed 30, 2012 1:05 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3352 Location: Advance, NC USA
noisebox wrote: .... Two more bumble bees and I'm done with the recap! I came close to the "hole in one" of recapping - where the TV comes up with great Raster, Sound, Video. When I powered my Raytheon TV, the Vertical Blocking Oscillator Transformer was open. That was all that was wrong. I was close but no Ace:-) Received a replacement transformer today and now its working. As meticulous as you have been with your Zenith Porthole, maybe you will get working on first power up - pulling for you. Carl
| Top |
noisebox
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: May Wed 30, 2012 1:16 am |
Thanks for the vote of confidence Carl. I'm hoping it wakes up from its long sleep without too much trouble. I'm still fighting this upper respiratory infection and wish I had more energy on this day off to dig into the resistors. What I need to do instead of pecking away at them is make a list of all the replacements I'll need and order them all at once. I was pretty good in ordering the caps. All I need is one more. I'm going to go check out your Raytheon!
| Top |
noisebox
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: May Thu 31, 2012 9:16 pm |
I hope I'm not boring anyone with my obsessive details. This is how I'm dealing with the resistors since there are so many. I've discovered a website with a neat resistor color calculator and I run it on my phone. I went through every section on the chassis and using the calculator, I write down the value of each resisistor. I then made a master list noting wattage and multiples of any of the values. With the list in hand I went to my resistor collection to see which ones I already have. I'm going to order the missing values with extras since they're cheap and whether I use them in this set doesn't matter. I'll have what I need on hand. Payday tomorrow and time to place an order
| Attachments: |
| Top |
Doug66
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: May Thu 31, 2012 9:35 pm |
Joined: Mar Wed 30, 2011 5:37 am Posts: 587 Location: GA
That's pretty cool. What fustrates me is some replacement resistors use a different cod for the third band. Ex Red Red Orange (22K) would be Red Red Black Red. I ordered a kit of replacement resistors last yr which are printed like that. Very confusing.
Doug
| Top |
noisebox
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: May Thu 31, 2012 10:59 pm |
I didn't know that. The ones I've been getting seem to always match.I'm the paranoid sort though and I always test the new ones. Where did you get the kit from?
| Top |
Doug66
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: May Thu 31, 2012 11:13 pm |
I think it was someplace overseas like Hong Kong. I found it on Ebay. The resistors work great, and the kit was a good price, but just confusing. I make sure to check each new one with my meter before using. Here is a pic one one that SB 3300 (orange orange red). It's coded orange orange black brown. Doug
| Attachments: |
| Top |
cwmoser
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: May Thu 31, 2012 11:27 pm |
| Member |
Doug66 wrote: I think it was someplace overseas like Hong Kong. I found it on Ebay. The resistors work great, and the kit was a good price, but just confusing. I make sure to check each new one with my meter before using. Here is a pic one one that SB 3300 (orange orange red). It's coded orange orange black brown. Doug Doug, I have a similar set of resistors - strange coding and some colors are hard to distinguish. Like you, I always check them with my Ohmmeter. Carl
| Top |
Doug66
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: May Thu 31, 2012 11:33 pm |
Noisebox, did you ever locate a test CRT? I've been looking for one myself for the 1951 Magnavox I'm restoring.
Doug
| Top |
Tom Schulz
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: Jun Fri 01, 2012 12:48 am |
| Member |
Joined: Mar Sun 01, 2009 10:27 pm Posts: 2914 Location: Ann Arbor, MI
Doug66 wrote: I think it was someplace overseas like Hong Kong. I found it on Ebay. The resistors work great, and the kit was a good price, but just confusing. I make sure to check each new one with my meter before using. Here is a pic one one that SB 3300 (orange orange red). It's coded orange orange black brown. Doug Those are most probably resistors with a tighter tolerance than 5%. For those they sometimes want more digits of precision. So instead of marking it 3 3 times 100 they marked it as 3 3 0 times 10.
_________________ Tom
| Top |
noisebox
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: Jun Fri 01, 2012 8:35 pm |
Doug66 wrote: Noisebox, did you ever locate a test CRT? I've been looking for one myself for the 1951 Magnavox I'm restoring.
Doug I'm still waiting to hear back from FrankB here on the forum. He says he might have a or 8XP4. I think he said he has a few--and he has around 250,000 things to sort through to find it  I put an ad in the ARF classifieds.
| Top |
noisebox
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: Jun Sat 02, 2012 7:25 pm |
I placed my resistor order today. I should be able to get back to work on the rest later this week. Still no word on the test CRT. If I can't get it by the time I finish the resistors I'll use the original to see where I'm at.
| Top |
neali
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: Jun Sun 10, 2012 2:36 am |
Joined: Mar Thu 31, 2011 4:52 am Posts: 1792 Location: Long Island
Tom Schulz wrote: Doug66 wrote: I think it was someplace overseas like Hong Kong. I found it on Ebay. The resistors work great, and the kit was a good price, but just confusing. I make sure to check each new one with my meter before using. Here is a pic one one that SB 3300 (orange orange red). It's coded orange orange black brown. Doug Those are most probably resistors with a tighter tolerance than 5%. For those they sometimes want more digits of precision. So instead of marking it 3 3 times 100 they marked it as 3 3 0 times 10. Tom, Perfect answer. 1% metal film resistors require three digits and an exponent. 5% carbon resistors require 2 digits and an exponent. The metal film resistors are better than carbon comp. They won't drift and they are mostly fireproof.
| Top |
noisebox
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: Jun Sun 10, 2012 8:00 pm |
Speaking of resistors... They didn't arrive yet. Hopefully Monday, which is my day off. They're coming from Just Radios in Canada and I think the dog sled got hung up at the border. In the mean time I've been working on the cabinet. The top was pretty messed up, which I'm finding is common for the tops of a lot of old radios and tvs. I stripped the finish and used a small wire brush with stripper to open up the grain and get rid of the majority of the black spots and gouges. Now I'm filling the grain back in. I'll have to re-tone to a darker mahogany as well. These are well-built cabinets. Stay tuned for more pics as I progress.
| Top |
noisebox
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: Jun Tue 12, 2012 2:26 pm |
Got the resistors yesterday It turns out I have a bunch of the 1% with the bad coloring and extra stripes. Time to get busy.....
| Top |
noisebox
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: Jun Wed 13, 2012 1:30 am |
Went cross eyed working on the resistors today so I had to stop. The approach I'm finding easiest is to work on the resistors that are in close proximity to tube sockets. They're easy to find on the schematic that way as well. Then I'll move to the more obscure ones where I have to trace wires back to a recognizable component.
I've had this respiratory thing turn to pneumonia and so my energy is down a bit. I'm trying to rest as much as I can before I go back to work Wednesday afternoon.
At this rate it might take me until next Tuesday before I fire it up. In the mean time I'm working on misc odds and ends with the cabinet, bezel etc.
| Top |
DaveM
Post subject: Re: My First Zenith Porthole ~ Restoration Posted: Jun Wed 13, 2012 1:57 am |
Joined: Aug Thu 07, 2008 1:36 pm Posts: 2067 Location: Orlando
just curious, are you replacing every resistor or just those that are way off? I don't want to sound alarming, but you are doing so much part replacement that you risk making part replacement errors in multiples that could make trouble shooting a real nightmare. Note on tube sets most resistor values are not super critical. For the most part I get replacing wax caps and bumble bees and maybe the electros if they test bad (I like to leave them alone if ok for the initial check out).
The idea being to do as little as possible for a quick base line test, then going in and replacing say the filter caps (as a precaution) and resistors (if there is a problem). I suppose if you are SUPER careful which may be the case as you seem to be very meticulous so far, then you minimize the chance of errors. Just be very mindful of things like broken leads on fragile coils, shorts between tube sockets, just anything that is disturbed can lead to a break/short.
All the warnings aside I commend your efforts so far, and hope it all works when done.
| Top |
Users browsing this forum: No registered users and 2 guests |
