I thought I had a good idea where to look to solve this problem but it is proving to be even more of a challenge - Started this set a while back - all caps changed, tubes good, resisters checked for values - all seems ok but I have a triple picture. The first 3 seconds after a the crt comes to life gives a resonable picture but then it falls apart..... sound is fine - Im thinking there must still be a resistor somewhere that is not cooperating, one that is really close to its needed value but off enough to cause a problem - checked over the sync section for these buggers - any ideas guys???? Thanks in advance
Mr."G"
