It is currently May Sat 18, 2013 9:12 pm
 Post subject: moving my motorola Vt-105 does this set need picture removed
PostPosted: Jul Fri 20, 2012 4:07 am
hello Guys,
I'm getting ready to move my unrestored motorola tv model Vt-105 ,
300 miles across the state to my new home Where I want to restore it.
Does the picture tube in this set need to be removed like with those Rca 8t241 sets that use the poor picture tube mounting.
far as this set goes I have not checked to see if it's jug is any good but do have a rebuild one to use.
Any way I don't want the set to get damaged any going over the mountains.
Sincerely Richard
 Post subject: Re: moving my motorola Vt-105 does this set need picture rem
PostPosted: Jul Fri 20, 2012 4:17 am
I have a VK-106, which uses the same chassis. I transported mine from Minnesota to Michigan in a U-Haul trailer. The CRT is securely attached to the chassis, so just ordinary care and precautions in securing it for transport should be just fine.
tvontheporch.com
PostPosted: Jul Fri 20, 2012 5:32 am
I had mine shipped cross country by UPS with no problem, the box looked like they rolled it the last 100 miles.
PostPosted: Jul Fri 20, 2012 6:29 am
Hello Eric,
thanks!! I'm going to restore that set for my apartment bedroom tv :D
Just wanted to make sure it was not like that RCA chassis
PostPosted: Jul Fri 20, 2012 6:55 am
That includes making sure that the CRT mounting hardware and chassis are snugged down. Don't assume that the previous owner left them tight. I have found plenty of old radios & TVs with chassis screws loose or missing, etc.
PostPosted: Jul Fri 20, 2012 7:05 am
Good point Phil.
PostPosted: Jul Fri 20, 2012 8:49 am
hello Phil,
thanks I'm also taking my national 7in if I have room those two tv's will be my first restore
Post New Topic Post Reply  [ 7 posts ]  Moderators: Mr. Detrola, 7jp4-guy
