It is currently Jan Mon 22, 2018 1:32 am
 Post subject: Merry Christmas To Me--New Project
PostPosted: Dec Mon 26, 2016 6:04 pm
Snagged a very decent Andrea TVK-12 and expect to be picking it up in a few days. The chassis looks like a DuMont (or DuMont inspired) model, such as an RA103. It appears to have the Mallory Inductuner. Anybody know much about these sets, any tips or comments about these models? I'll be doing the usual complete recapping and component checks and going from there. If there's any thing in particular I oughta look out for I'll appreciate the heads up! :mrgreen: Haven't dug into a tv in a few months now so I'm getting' a little itchy for some new fun!
George
 Post subject: Re: Merry Christmas To Me--New Project
PostPosted: Jan Sun 01, 2017 11:00 pm
Hi Again All, Picked up the new TV yesterday. Looks pretty damned good all in all. A nice survivor. The cabinet most definitely won't need a restoration, just a cleaning and a once over with Howard's and a coat of wax. The chassis is VERY original and seem unmolested. I'll do the usual recap and check of resistors over 20% out of spec and power it up and see where we are. The CRT has a CRT brightener on it. It is what I assume is the original DuMont 12QP4. I think I may have another 12QP4 on a shelf back at my storage spot; if not and if this CRT is shot, I think I can swap in a 12KP4...... Does not seem to have ever been messed around with. Chassis seems awfully similar if not identical to the DuMont RA103. Anybody have any knowledge into this? The chassis is the TV-12 Looks to me to be a nice winter project :mrgreen:
-George-
PostPosted: Jan Sun 01, 2017 11:58 pm
Wow, cool project. Good for you.
Crist
PostPosted: Jan Mon 02, 2017 12:22 am
Similar to a Dumont RA-103, but maybe incorporating Andrea circuitry also? The two pioneering companies probably "shared" design info to produce their respective products. Whatever the connection, both companies produced excellent receivers, IMO. Happy that you found one in such nice condition!! :D Best wishes for a rewarding restoration!
Kevin
"There Is Nothing Finer Than A Stromberg-Carlson"
PostPosted: Jan Mon 02, 2017 2:05 am
That's super nice and it looks all original. I don't know how you feel but I would rather work on a unit that has never been serviced underneath the chassis. It makes it super easer using SAMS.
PostPosted: Jan Mon 02, 2017 2:06 am
I've wondered why a 6AL7 eye wasn't incorporated in this set?
Nice find! :D
PostPosted: Jan Mon 02, 2017 3:27 am
That's exactly how I feel about really original sets that haven't been serviced sub chassis. It says there much less chance for weird stuff caused my Mickey-mousing, and that the set may very well have no serious issues, or others would have done work under there to correct it. Defnitly a high quality set though and nearly as heavy as a DuMont!! I think this one was probably getting a weak CRT and the owners decided it was time for a new TV rather than buy a new CRT.
George
PostPosted: Jan Mon 02, 2017 4:13 am
Nice find. Those were high-quality sets. I had found a near mint original fresh from an estate years ago and so regret selling it. Good luck with your resto. That'll be a great player once restored.
PostPosted: Jan Wed 04, 2017 11:02 pm
Outside of the Mallory InducTuner, I really don't see a connection to the DuMont.
Anybody else want to illuminate me?
“You can always count on the Americans to do the right thing after they have tried everything else.”
PostPosted: Jan Wed 04, 2017 11:12 pm
Here's mine. I like this set. A lot. 8)
PostPosted: Jan Thu 05, 2017 12:51 am
Between these two, I hope to make one good one.
PostPosted: Jan Thu 05, 2017 4:04 am
Oh come on. You should try to make two good ones!
PostPosted: Jan Thu 05, 2017 4:53 am
I haven't had a chance to look any closer at the chassis. The inclusion of the AM tuner on the main chassis is different from DuMont, but visually chassis looks darned similar to my RA103 Chatham. As I dig into it I'll likely find lots of differences thiugh.
George
PostPosted: Jan Thu 05, 2017 4:55 am
That's a darn nice cabinet!! What did you do to it to bring it up like that? Very sweet :mrgreen:
PostPosted: Jan Thu 05, 2017 12:19 pm
Perhaps I could. The red one has a lot of delaminating and veneer damage on the cabinet, but if I have two good chassis/CRTs, yet two working sets, but also only one set of knobs.
I do like these sets with AM/FM radios built-into the TV chassis. The GE 901, Stromberg Carlson TS-125 and Garod 10TZ4 are excellent examples too.
PostPosted: Jan Thu 05, 2017 3:49 pm
Link to my restoration:
viewtopic.php?f=3&t=189002
PostPosted: Jan Thu 05, 2017 8:03 pm
Lee, thanks for the link to your restoration.
I'm sure its an inspiration for George as well as myself.
PostPosted: Jan Fri 06, 2017 1:09 am
M3-SRT8 wrote:
You did a real sweet job on that set. Thanks for sharing the post. I think my cabinet is in better shape than yours was when you started but I may use your techniququd with the 600 paper and Howards. I'll keep everyone posted as I go along.
George
PostPosted: Jan Fri 06, 2017 3:55 pm
If the finish is better than mine, start with 1000 grit and go to 3000 using Howards.
Watch the edges! You can go through the vineer quite easily. Rub straight with the grain. Take it slow and easy.
PostPosted: Jan Fri 06, 2017 8:10 pm
Good thoughts. Will start at 1000 In an inconspicuous spot. And yes I've learned about veneers and their vulnerabilities the hard way!!
I need to go thru the chassis first then attack the cabinet. I usually do this while letting the chassis play on the bench while I work. Then if any other issues crop up I can I'd them and get them right before reassembly
George
Post New Topic Post Reply  [ 20 posts ]  Moderators: 7jp4-guy, Mr. Detrola
