It is currently Jun Wed 20, 2018 2:02 pm
Post New Topic Post Reply  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Admiral 20A1 recap - Need Advise
PostPosted: Feb Sat 24, 2018 2:24 am
The set will run without the width coil. You could then scope around to find a candidate for the ref pulse.
PostPosted: Feb Sat 24, 2018 3:29 am
robert1 wrote:
this is why i asked if i could replace the coil with a standard width coil & try to find another source for the horizontal sync pulse. i notice that the later Admiral chassis designs use a different method of sourcing the sync pulse
One problem with using a standard width coil is getting one with the right inductance. Now if schematic for your set specifies the inductance, than you could try to get a new coil to match. Or you could try whatever you can find and see if it works. You could always wind a new secondary on to a standard coil. The secondary would not have to be precision wound and would not have many turns.
PostPosted: Feb Sat 24, 2018 4:53 am
Both the Sams & Riders manuals do not specify the inductance, but Sams shows it as 80 ohms for the Primary & .5 ohm for the secondary.
i really don't have any parts like that here so i would have to look (& guess) online for something that might be close.
as for the the winding, can it be wrapped around the outside of the width coil winding?
PostPosted: Feb Sat 24, 2018 7:33 am
Hi Robert,
I did some checking on 20b1 set I have, and found that the primary inductance adjusts in the 9 to 12 mh range. The secondary adjusts through 530 uh. I took these readings with the wires removed from the coil. Also remember that the adjusting core of the coil increases overall inductance. I noticed that the secondary coil is wound with heavier wire, 26 to 28 gauge wire. I measured 78.8 ohms for the primary winding.
If you get a standard replacement coil , it shouldn't be too much trouble to wind the secondary over the primary. Just try and count the secondary turn off the original coil.
Ed
PostPosted: Feb Mon 26, 2018 7:21 pm
Perhaps this Workman T121 width coil available from Talon will work ?
http://www.talonix.com/shop/item.aspx?itemid=3660
Chassis mount, Transformer,
Primary resistance 102 ohms,
Primary Inductance 9 - 24 mH
Secondary (AGC winding) resistance 1.2 ohms
Secondary Inductance .25-1.1 mH
PostPosted: Feb Mon 26, 2018 9:12 pm
Wow, Thanks, Bob. i believe that may fix it. i just ordered it. i will post back on this topic once i get it installed (which may be a couple of weeks)
Post New Topic Post Reply  [ 26 posts ]  Moderators: 7jp4-guy, Mr. Detrola Go to page Previous  1, 2
Users browsing this forum: Pearson and 7 guests
