It is currently Jun Mon 18, 2018 10:02 pm
 Post subject: Help with GE/Hotpoint portable
PostPosted: Sep Sat 09, 2017 2:54 pm
Model 14S203: Two red wires and a blue come out of the chassis and connect to the yoke, but to which terminals? It's been worked on enough two of those wires just fell off just by touching. Repair people must have had fun with these.... Thanks, Craig p.s., it"s Sams 356-8
 Post subject: Re: Help with GE/Hotpoint portable
PostPosted: Sep Mon 11, 2017 2:58 am
locate where on the chassis the wires come from then follow the schematic to see where they go.
PostPosted: Sep Mon 11, 2017 2:33 pm
Thank you Thomas. The following is for posterity. Blue goes from pin 3 of the damper to pin 5. Red wire from vert output transformer to pin 3. Low B+ goes to pin 6, common to both. I used a piece of u-tube (thanks, shamo066) for help. Word of warning, if you don't get it right the first time, it's likely to blow the flyback as it doesn't like to see unusual loads. Craig
PostPosted: Feb Mon 26, 2018 9:33 pm
I am having the same problem, when I took the chassis out the yoke just fell out with it! I have a question though, I do not see any indication of what pin is which on the yoke. For example, what is pin one? I did see that YouTube video by shango066, but I could not get a real good look at it.
PostPosted: Feb Tue 27, 2018 11:28 pm
Nevermind, the yoke is very dirty but after inspecting it there are little numbers stamped next to each pin.
Post New Topic Post Reply  [ 5 posts ]  Moderators: 7jp4-guy, Mr. Detrola
