It is currently Oct Wed 17, 2018 10:51 am
 Post subject: RCA GB 685 H
PostPosted: Nov Mon 13, 2017 10:13 pm
I just picked up an old RCA GB 685 H
Looks to be manufactured February 1978.
Plug it in nothing happens with turning any knobs or switches.
Can someone more knowledgeable point in the direction of some resources.
What do I start with.
 Post subject: Re: RCA GB 685 H
PostPosted: Nov Tue 14, 2017 5:42 pm
First, welcome to the forums.
Like with any journey, getting to a destination (in this case a working TV) depends on where you start from.
Giving people here some background on your possible capabilities, experience, and electronics test equipment that you bring to the party is kind of important.
In the mean time, I found something you may need in the process; documentation on what is in your TV.
Your TV is in Sams Photofact Folder 1703-1 as shown below. This documentation is available for sale as shown. I did not see any free online versions, but they may exist.
Curtis Eickerman
PostPosted: Nov Tue 14, 2017 8:10 pm
I've more experience in Automotive electronics DC. Though given some time I think I can mostly figure out a detailed schematic if I have one. I mostly only have a typical good quality multimeter. Though whatever tools I need then I just need to get it. I'm more or less familiar the basics of radio technology, i.e transistors, capacitors, inductors and such though I definitely have a very long way to go.
My chassis is a CTC-86.
And yes I'm aware of the high voltage potential though not certain on what is the best way to discharge it without getting lit up like a Christmas tree.
Though as it's been sitting non operational close to I'd say 10 years I doubt it's still to hot but better safe than sorry.
It's dead in the water, no glow no clicking no static in the speaker, no nothing just dead.
PostPosted: Nov Tue 14, 2017 10:47 pm
Where is you spirit of adventure? :shock:
Seriously though, I have a very long screw driver that I alligator clip lead to the chassis. Then touch the end of it to the HV lead to make sure things are discharged.
With that, I will bow out. There are others here who are much better equipped to help you with TV troubleshooting than I am. I am more of a radio guy.
Best of luck.
Curtis Eickerman
PostPosted: Nov Tue 14, 2017 10:49 pm
PostPosted: Nov Tue 14, 2017 11:09 pm
Next step is open it & take a good chassis picture ( nudie ) & post it.
That way everyone that worked on then years ago will remember it.
IF its the set I am thinking it is there are a few easy fixes if you are lucky.
1) popped breaker. Little red button sticking out the back.
2) bad on off switch
3) bad AC cord !
4) thermistor behind chassis that falls apart.
good luck
Zeno 8)
LFOD !
PostPosted: Nov Wed 15, 2017 5:28 pm
Well it won't let me upload a picture says it's too big. So far I've checked the cord, good 120v, the 4 diodes on the power board, all good, and the fusible resistor .1 ohm. Only thing left is it says there's a fuse on the board. I'm not familiar with what it might look like. Though I do have a little red disc soldered into the board it shows OL. Would that be my fuse?
Number on it is General Electric 773-1 and then it says x7
PostPosted: Nov Wed 15, 2017 11:44 pm
You can use an art program like Microsoft Paint to resize your photo to 800x600 pixels or smaller.
Phil's Old Radios
PostPosted: Nov Thu 16, 2017 3:02 pm
Ive found the problem. It's got a bad power switch
PostPosted: Nov Thu 16, 2017 4:26 pm
Some RCA on/off switches can get stuck half way mechanicly. You can see it from the outside
if so. Just give it a push.........
BTW I pulled the Sams & yours was a short lived chassis. Saw only a hand full
unlike other RCA's that we saw by the 100's. It was the last modular set they built.
73 Zeno
LFOD !
Post New Topic Post Reply  [ 10 posts ]  Moderators: 7jp4-guy, Mr. Detrola
