It is currently Jun Sat 23, 2018 6:42 pm
 Post subject: PANASONIC ORBITEL TR005
PostPosted: Jan Wed 31, 2018 8:36 pm
Just finished having this neat space age set restored,, working great. The front of the screen has a tinted clear curved removable cover that over the past 40 years had become cloudy and I cannot clean it with any plastic polishes. Has any one had any good results with any other options to clear cloudy resin or plastic covers? I see that there is a heat process that works, but I do not want to melt the cover. The cloudiness is thru the entire plastic, not a scratched surface. Any suggestions appreciated.
 Post subject: Re: PANASONIC ORBITEL TR005
PostPosted: Jan Wed 31, 2018 11:20 pm
I wonder if some of the products sold in auto supply stores to restore cloudy headlight lenses might work in this case.
Mark Nelson
tv-boxes.com
PostPosted: Feb Thu 01, 2018 7:54 am
What polishes did you try?
How do you know the cloudiness goes all the way through the material?
A guy near here is trying to sell an Orbitel with a broken cover (chunks missing). I wonder if anyone has ever tried to make a repro cover?
Phil's Old Radios
PostPosted: Feb Thu 01, 2018 2:04 pm
All the Novus polishes, Mothers for headlights all fail. The cover is cloudy, or milky, not the usual discoloration like on auto lenses. I think it is just from it sitting somewhere for 40 years. The surface is perfectly smooth, but not very clear. It was originally a smoked plastic cover. I asked Mark Palmquist, that makes radio covers, and he has no interest. I did see on You Tube where some kind of torch cleared the plastics used on pinball machines that were cloudy, but I do not want to ruin the cover. I am sure there is some way to fix it.
PostPosted: Feb Thu 01, 2018 7:57 pm
I agree, don't use heat.
A replacement would probably be your only option.
PostPosted: Feb Thu 01, 2018 10:49 pm
Before trying something drastic like a torch, you might consider making a mold for reproduction, using your cloudy cover as the model for a mold. This company supplies casting products and has lots of info about techniques:
https://www.smooth-on.com/
Even if you're not interested in making a repro right now, at least making a mold would give you some kind of fallback if your torch turns the cover into a puddle.
Phil's Old Radios
Post New Topic Post Reply  [ 6 posts ]  Moderators: 7jp4-guy, Mr. Detrola
