It is currently Jan Tue 22, 2019 12:48 am
 Post subject: Advent model 710 followed me home
PostPosted: Feb Sun 04, 2018 12:35 am
It was free...any of you guys have one? Where can I find service info for it?
Thanks in advance.
 Post subject: Re: Advent model 710 followed me home
PostPosted: Feb Sun 04, 2018 8:39 am
I used to work on these back in the 70's.
There was a service manual but it was somewhat incomplete as I recall. Certainly nothing about the mod details - see below- and that's where most of the trouble was.
I will see if I can locate the guy I used to work for - Bruce Cliff - if he's still alive....
You never know, he might still have the manual stashed somewhere.....
The model I knew came from the US as an RGB monitor and had a PAL front-end added locally, using NEC modules and tuner, I guess because they were readily available as spare parts..
Could you post a few pics and I'll tell you if it looks the same?
I did find this forum topic from which you might find someone who has a manual....
http://www.videokarma.org/archive/index.php/t-5688.html
PostPosted: Feb Sun 04, 2018 6:45 pm
Apparently you did not run fast enough! :)
PostPosted: Feb Mon 05, 2018 1:30 am
Back in the 90's I worked for the cat that bought everything from Advent for pennies
on the dollar. He made a fortune on it. By 2000 there was next to nothing left
& since only a few came in a year it went to the dump.
Anyhows all the ones I worked on were either Sylvania or Electrohome chassii. If
it uses 3 big modules its a Sylvania. Easy to fix. Just the CRT adjustments are different
but thats not an issue unless you change one of the jugs.
73 Zeno 8)
LFOD !
PostPosted: Feb Mon 05, 2018 1:45 am
I'll try to post pics tomorrow. It was built in October of 1979. It has audio but zero video. I'll open it up tonight and see what the internals look like.
PostPosted: Feb Tue 06, 2018 12:55 am
It's an electrohome chassis.
PostPosted: Feb Tue 06, 2018 2:16 am
https://photos.app.goo.gl/PqEAZOqRWRQyY6N93
PostPosted: Feb Tue 06, 2018 2:19 am
Ooooo! You REALLY didn't run fast enough!
PostPosted: Feb Tue 06, 2018 2:34 am
https://photos.app.goo.gl/MUblQCVoTLMwUKnF2
I know... LoL!
Post New Topic Post Reply  [ 10 posts ]  Moderators: 7jp4-guy, Mr. Detrola
Users browsing this forum: ecaden1 and 3 guests
