Page 1 of 1
[ 16 posts ] |
| Author |
BOB BONCHAK
Post subject: Weltron Model 2001 Questions Posted: Dec Thu 29, 2011 3:23 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1296 Location: SOUTHLAKE, TX, USA
Picked up this "Space Age" (1970's?) transistor AM/FM Stereo 8 - Track player recently. Works/sounds great on all functions. Two problems. Rod antenna needs to be replaced. On/off pilot light appears to be blown. Anyone know how to dissassemble this unit to get at the antenna and lamp? I can't figure it out. Also, Sams data is at TSM-131. Can anyone share that with me? TIA BOB
| Top |
PBPP
Post subject: Re: Weltron Model 2001 Questions Posted: Dec Thu 29, 2011 5:13 am |
Joined: Jun Tue 21, 2011 8:27 pm Posts: 2214 Location: Virginia
You're in luck. I just ordered TSM-131, along with a few other Photofact manuals. Should be here in a few days. Will be happy to scan the schematic and send it to you. PM me with your email addy and I'll send it along.
~ Mitch ~
| Top |
crvee8
Post subject: Re: Weltron Model 2001 Questions Posted: Dec Sat 31, 2011 9:11 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 159 Location: Melbourne, Australia.
Hi Bob, To disassemble the cabinet is fairly easy. You lift the top half of the case off first by unscrewing two philips head screws located under ther top handle. The top half should then lift off. You can then access the telescopic antenna. You then can then see four philips head screws holding the chassis to the bottom half of the case inside on four corners of the chassis. Also unscrew the headphone jack nut at the bottom of the case. Undo those and the bottom half of the case can be removed. The front panel is held to the chassis by four philips head screws. Remove the knobs undo the screws and unscrew the microphone socket nut and the front panel will come off giving access to the lamps. Normally the power lamp and the FM stereo lamp is blown on these. The best way to get the right globe for these is to measure the voltage across the leads. I have seen some variations in voltages on these depending on build models. They used those grain of wheat style bulbs. I used grommets to remount replacements in the ones I have repaired as the originals had rubber mounts that are usually deteroirated with age.
| Top |
BOB BONCHAK
Post subject: Re: Weltron Model 2001 Questions Posted: Jan Sun 01, 2012 12:13 am |
crvee8: THANKS!! That is exactly the type of dissassembley information I was looking for. Would never have figured it out without your gracious assistance. Will try to get to it in the next couple of days. With your instructions, replacing the antenna and lamps should be no problem. Interesting that the Sams data does not contain the dissassembly information or the lamp specifications. Thanks again. BOB
| Top |
HadYourPhil
Post subject: Re: Weltron Model 2001 Questions Posted: Jan Fri 06, 2012 2:05 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1294 Location: Naples, FL USA
Used to work on those way back when. Pretty easy to take apart, and those little bulbs don't last too long. Odd looking unit. We sold 'em new back in 1969-70
_________________ We improve things by making them worse...
| Top |
PBPP
Post subject: Re: Weltron Model 2001 Questions Posted: Jan Fri 06, 2012 10:58 pm |
Hey Bob, Got the Sams TSM-131 today and it has your Weltron in it. Wow! What a throwback to 1972 and 8 track players. These are pretty collectible now on ePay, but I wouldn't buy one. No offense, it's just not my style........ anymore. ~ Mitch ~
| Top |
br1zapp
Post subject: Re: Weltron Model 2001 Questions Posted: Apr Thu 12, 2012 3:15 pm |
Mitch, I would be very happy to receive the scanned copy of all papers concerning Weltron 2001! I am curious about the FM stereo lamp data too[quote][/quote]! Many thanks! In change you may ask me something else...I do follow a lot of things, ask me and maybe I have it double or can help! Bruno Ferrara Italy email address: br1zapp@libero.it
| Top |
PBPP
Post subject: Re: Weltron Model 2001 Questions Posted: Apr Tue 17, 2012 5:35 am |
| Top |
wandoo
Post subject: Re: Weltron Model 2001 Questions Posted: Sep Wed 19, 2012 3:49 pm |
Hello there,
I just bougth a Weltron 2001 and need to replace the antenna... any idea where I can get a new / spare one? Any website? I found one for belt tape but not for fm antenna..
| Top |
PBPP
Post subject: Re: Weltron Model 2001 Questions Posted: Sep Wed 19, 2012 4:30 pm |
wandoo wrote: I just bougth a Weltron 2001 and need to replace the antenna... any idea where I can get a new / spare one? Any website? I found one for belt tape but not for fm antenna.  Welcome to the ARF forums RatShack carries three sizes. I could only find one description online: http://www.radioshack.com/product/index ... Id=2062262 ~ Mitch ~
| Top |
BOB BONCHAK
Post subject: Re: Weltron Model 2001 Questions Posted: Sep Thu 20, 2012 12:13 am |
WANDOO: No need to try to fing an "exact" replacement. The trick is to find a rod antenna with the correct mounting congiguration. Over the years, I have built up quite a stock of rod antennas, so replacement was easy for me, once I found out how to take the cabinet apart. My set works great with my "generic" replacement antenna. BOB
| Top |
rikroc
Post subject: Re: Weltron Model 2001 Questions Posted: Dec Sat 29, 2012 7:00 am |
What did these sell for in the Before Time?
| Top |
jay1028
Post subject: Re: Weltron Model 2001 Questions Posted: Dec Sun 30, 2012 3:58 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 190 Location: N.E. Florida
Mitch,
Thanks for the schematics. I was given one of these a while ago and it works so far. The white plastic is yellowing in places but looks like to much work to restore finish. Sure is big though.
Jay
| Top |
PBPP
Post subject: Re: Weltron Model 2001 Questions Posted: Dec Sun 30, 2012 4:56 pm |
Hi Jay, There's more information on the Weltron in TSM-121... diagrams, pictures, etc. Something like 13 pages of information if I recall correctly. There's one eBay seller who has multiple copies of that issue, (and others) for about $7.50 shipped. Cheapest source I know of. No affiliation. http://www.ebay.com/itm/150830940982?ss ... 1438.l2649~ Mitch ~
| Top |
jay1028
Post subject: Re: Weltron Model 2001 Questions Posted: Dec Sun 30, 2012 6:33 pm |
Wow, that guy has some inventory of SAMS books.
| Top |
PBPP
Post subject: Re: Weltron Model 2001 Questions Posted: Dec Sun 30, 2012 9:58 pm |
| Top |
Users browsing this forum: No registered users and 2 guests |
