It is currently May Fri 24, 2013 10:25 pm
 Post subject: Circuit board question
PostPosted: Apr Tue 17, 2012 12:59 am
Hi all.....When replacing caps or transistors on a circuit board, and the solder joint is gone......besides hard wiring from point to point...Is there a way to repair the joint? thanks AL
 Post subject: Re: Circuit board question
PostPosted: Apr Tue 17, 2012 1:27 am
the solder trace is gone or the pad is gone ? a piece of wire could replace a trace. solder adheres to existing trace if clean. the tiny pad can be replaced by solder. you can do a lot with just the solder
CAUTION: Im no expert
PostPosted: Apr Tue 17, 2012 1:30 am
What do you mean - gone? Do you mean the glue has separated the copper track from the board and the 'eyelet' has then broken off?
I would poke the lead of the new component through the hole then bend it to where you can solder it on to the remaining track. If it's quite a distance then cover the lead with a bit of sleeve and maybe a drop of glue to give some mechanical support to the component on the other side. Professional boards often have a dab of white silicon sealant (non-acidic) under larger components to prevent movement.
The usual cause of the track separating is overheating - especially if using solderwick to remove the excess solder - or pushing down on the component while it is still soldered on the other side.
Cheers - Marty ZL2MC
PostPosted: Apr Tue 17, 2012 1:40 am
Yes the eyelet is gone. Your right, it was caused by pulling the component through the hole...after using solder wick...I traced board, and hardwired that connection of a switching transformer to its connections...thanks AL
PostPosted: Apr Tue 17, 2012 1:49 am
There is paint-on liquid containing metal powder to make it conductive.
Silver is the best, but pricey. I think General Cement used to sell this stuff.
http://www.mgchemicals.com/products/8420p.html
PostPosted: Apr Tue 17, 2012 5:52 am
If you want to replace a damaged trace, you can use some #22 gage solid copper wire(depending on the size of the trace of course), flatten it out and overlay the trace. solder it over and drill a hole where the pad was then insert a wire or component lead and solder. Then lay a bead of epoxy over the repair.
Me repair, Smoking radios.
Visit our Webpage:
PostPosted: Apr Wed 18, 2012 3:36 pm
eyelets do come off sometimes for me as well. I make sure that the solder extends past the the component lead onto the trace dragging the solder with the iron. works for me
PostPosted: Apr Wed 18, 2012 6:39 pm
Thanks to all...very helpful! AL
Post New Topic Post Reply  [ 8 posts ]  Moderator: Dave Doughty
Users browsing this forum: psbot [Picsearch] and 2 guests
