Page 1 of 1
[ 5 posts ] |
| Author |
rocklandman
Post subject: No volume on AM & SW Sony CRF 230 but FM is Strong? Posted: May Wed 02, 2012 2:39 am |
| Member |
Joined: Jun Mon 06, 2011 3:52 am Posts: 628 Location: Hudson Valley NY
Just got this radio SOny CRF-230 and can't figure out why the FM is loud and strong but the AM & SW stations are so low in volume you have to put your ear next to the speaker at full volume just to barely hear anything? Is there something I am doing wrong?? Very puzzled. Thanks Rock
_________________ "Radios!!! I just can't get enough"!!!
| Top |
ariston
Post subject: Re: No volume on AM & SW Sony CRF 230 but FM is Strong? Posted: May Wed 02, 2012 12:26 pm |
| Member |
Joined: Mar Sun 20, 2011 2:53 pm Posts: 383 Location: Spain
The RF and IF circuits are differnts for AM and FM. Probably you have some IF AM transformers damaged or missaligned.
| Top |
compengsls
Post subject: Re: No volume on AM & SW Sony CRF 230 but FM is Strong? Posted: May Wed 02, 2012 3:44 pm |
| Top |
Dave Doughty
Post subject: Re: No volume on AM & SW Sony CRF 230 but FM is Strong? Posted: May Wed 02, 2012 4:02 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 13643 Location: Utica, NY 13502 (USA)
It could be just a dirty switch. For example, I would start by cleaning the FM1 and FM2 band selector switches. In their "out" position, they need to connect AM/SW audio to the amplifier section. The faint audio you are hearing might be due to capacitive leakage in the switch but the actual connection is not being made.
| Top |
Scott
Post subject: Re: No volume on AM & SW Sony CRF 230 but FM is Strong? Posted: May Tue 08, 2012 10:53 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1216 Location: NJ, 07645
It is 2 radios in one that share the same AF amp and power supply. I would start by checking the obvious like switches. Often if they are dirty moving them or gently shaking them reveals the problem. Otherwise, you need to work towards the front end (from the AF amp), injecting a signal to isolate the stage that is causing the trouble.
| Top |
