It is currently Jun Wed 19, 2013 3:13 am
 Post subject: Need recommendation for repairman for Realtone TR-970
PostPosted: May Tue 15, 2012 5:56 am
Hi all-
My Realtone TR-970 (3-band, MW-SW-LW) works fine on MW, but receives weakly on SW.
Who would you-all recommend to work on it?
Thanks much,
Lew
 Post subject: Re: Need recommendation for repairman for Realtone TR-970
PostPosted: May Tue 15, 2012 10:48 am
glew1 wrote:
Hi all-
Thanks much,
Lew
Real dumb question time: you've checked the bandswitch, antenna connections, etc., right? The fact that your radio is receiving SW, but weakly, implies maybe you just need the bandswitch cleaned or perhaps a better antenna connected to the radio, especially if your radio only has a whip antenna. My 1960's & 70's transistor multiband radios don't receive much SW off the whip itself.
PostPosted: May Wed 16, 2012 2:53 am
Hi Lew,
I've kind of admired that radio. Cool styling. Also sold under the trade name Lincoln.
The schematic is in TSM-27 (Realtone) and TSM-32 (Lincoln). I can scan it for you if you'd like.
As far as repair, it may just need a touchup on the front end trimmer cap.
But I'd suggest a Q-Tip and 90% isopropanol alcohol on the bandswitch before anything else.
~ Mitch ~
EDIT: Added links to schematic:
http://oi45.tinypic.com/1pihib.jpg
http://oi50.tinypic.com/2l9gnk3.jpg
http://oi45.tinypic.com/169eyjd.jpg
http://oi48.tinypic.com/4fu8id.jpg
http://oi47.tinypic.com/upy5c.jpg
http://oi48.tinypic.com/2zgdac1.jpg
http://oi46.tinypic.com/6xwvpu.jpg
PostPosted: May Wed 16, 2012 8:06 am
Renton481 wrote:
glew1 wrote:
Hi all-
Thanks much,
Lew
Check, and double check: no improvement in SW reception. Thanks for the tips.
PostPosted: May Wed 16, 2012 5:56 pm
This isn't a communications style receiver, so I wouldn't expect great performance from it.
Adding a longwire antenna instead of the whip will really help here.
If you're convinced it needs an alignment, adjust A13 and A15, noting there original positions.
Do not adjust A12 and A14, unless you really know what you're doing.
It's possible you can gain a bit more sensitivity by slightly adjusting the if cans,
but more than likely they're OK.
It's easy to get in there and twiddle on those adjustments only to find you've made things worse.
Been there, done that. :lol:
~ Mitch ~
PostPosted: May Thu 17, 2012 3:39 am
~ Mitch ~
That sounds like real good advice.
Maybe I'll just leave well enough alone.
Post New Topic Post Reply  [ 6 posts ]  Moderator: Dave Doughty
Users browsing this forum: Google [Bot] and 5 guests
