It is currently May Thu 23, 2013 3:11 am
Post New Topic Post Reply  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: HOW GOOD IN SW YOUR RADIO IS ?
PostPosted: Aug Tue 07, 2012 5:18 am
TonyC
the only one that I think might be working below par is the TO. It's just never lived up to my expectations
Perhaps Transoceanic radios aren´t as good as we though, I have a D7000Y and it doesn´t live up to my expectation neither.
I love all your radio well almost all, except one the RS DX440. A year ago I bought one and immediately sold it I couldn ´t stand the cho-cho.
At what frequency did you do the test ?
PostPosted: Aug Tue 07, 2012 5:29 am
Same as you, 15.6 Mhz with 10% modulation. If your generator is calibrated, we could still be different by 3 db. Some generators have output levels that reflect unloaded output, and some reflect the output level with the proper termination. The Boonton output level is correct with a 50 ohm load (and I doubt that any of these radios is 50 ohms at 15.6 Mhz). My Jung Jin synthesized generator, which is a similar vintage to yours, is close when it is unloaded.
I use the DX440 because the dial is accurate. Mostly it is a piece of test equipment for spotting local oscillators when aligning radios. It is also quick to set the frequency with the keypad.
Tony
Tony Casorso
Post New Topic Post Reply  [ 22 posts ]  Moderator: Dave Doughty Go to page Previous  1, 2
Users browsing this forum: Bruce Webster and 3 guests
