It is currently Nov Sat 18, 2017 9:01 am
 Post subject: Zenith Royal 500(B) drifting
PostPosted: Feb Wed 22, 2017 8:06 pm
Good morning Gents,
I recently picked up an old Royal 500 variant from a friend, did the usual re-cap, and the radio works admirably.
I'm running into something where the set is "drifting" though, when tuned into the local AM station that plays oldies, every so often it will drift off-frequency, and need a touch of the dial to reset it. I've never messed with any of the early transistor sets, much less a Royal 500, so I must say I know next to nothing about them, any thoughts?
I believe mine is the B variant, as it's the black case, but has the printed circuit board as compared to the point-to-point wiring that the first ones had. Quite the nice little radio, and for what it is, the sound isn't bad either.
Any thoughts or opinions about this would be most appreciated, I'm finding myself growing more fond of the set as I use it!
Thanks in advance,
Best regards,
"PRO PATRIA VIGILANS"
(Watchful for the Country)
Last edited by signalcorpsoperator on Feb Thu 23, 2017 5:32 pm, edited 1 time in total.
 Post subject: Re: Zenith Royal 500(B) drifiting
PostPosted: Feb Thu 23, 2017 9:04 am
make sure the battery connectors are clean And check the battery voltage under load.
Visit our Webpage:
PostPosted: Feb Thu 23, 2017 5:30 pm
Sounds good, I'll check on that!
Thanks!
Post New Topic Post Reply  [ 3 posts ]  Moderator: Dave Doughty
