It is currently Feb Tue 20, 2018 2:39 pm
 Post subject: GE 860F Mixer Output
PostPosted: Jan Sat 07, 2017 11:49 pm
Need some help. Losing my hair (and sleep) on this one. The collector of the mixer has a 6v peak to peak signal that tracks the oscillator frequency. I should see a much lower signal. Thinking the IF might be oscillating, I jumper-ed all the rf bypass capacitor with no improvement. No reason to suspect the mixer transistor, but I pulled and tested it anyway. Bias reading good on all transistor. If I tune to the high end of the band the signal goes away and I can pick up a radio station or two . Thanks for looking
 Post subject: Re: GE 860F Mixer Output
PostPosted: Jan Sun 08, 2017 4:44 am
Hey Joel,
Did your IF's align well with 455 kHz ?
I worked on one of these a couple years ago: viewtopic.php?f=4&t=217887
Seem to remember that the oscillator output was fairly high amplitude-wise...
Hope that thread helps !
They are not fun to work with...
PostPosted: Jan Sun 08, 2017 6:01 am
xrhonda91......I think I did see your post. I have been digging through the schematics of my radios to find one similar so I can do a comparison. The 455KHZ IF did peak out but the oscillator signal is so high at the first IF that it is making it way to the detector and creating havoc. The mixer feeds a IF transformer setup that different than what I am use to seeing. Maybe it will be higher.....
Thanks for looking.
P.S. Did you like the sound of your GE. Nice size speaker. I was hoping for a nice sound .......
PostPosted: Jan Sun 08, 2017 5:30 pm
Hello Joel,
The audio is pretty flat, but clear with plenty of usable volume when working correctly.
When my IF's were bad and I could only receive the stronger locals with very "broad" tuning, the sound quality was full & excellent (probably due to the wider bandwidth caused by the IF faults ?)...
How are the osc & mixer transistor voltages ?
Would it help if I pulled the cover on mine and scoped the oscillator output ?
PostPosted: Jan Sun 08, 2017 5:39 pm
If you would put a scope on the collector of the mixer you would forever be my hero..... 1 million thanks
PostPosted: Jan Sun 08, 2017 5:50 pm
Getting ready to play in shop-room now---may be this evening before I get back on here.
PostPosted: Jan Sun 08, 2017 7:10 pm
Hey Joel,
Wanted to do this first, so below are scope pics...
.1 V/DIVISION, 5 uS/DIVISION
Both the collector and emitter of mixer transistor readings are taken at both the bottom (550 kHz) and top (1600 kHz) of band with no signal present...
NOTE: I discovered that the Mixer E & C designations are REVERSED on the SAMS PCB trace side picture during troubleshooting back then and just noticed that I'd made correction on my printout.
Hope this helps !
PostPosted: Jan Sun 08, 2017 11:01 pm
most excellent. Just the info I needed. I want be able to take a look until tomorrow. I also noticed the error on the SAMs Photofact. Thanks for taking the time for the measurements and pics
PostPosted: Jan Mon 09, 2017 12:02 am
You're welcome !
Good luck and please let us know what you find...
PostPosted: Jan Mon 09, 2017 8:20 am
John your info was very helpful. As you can see my results are way off. As you can see I have a 6volt signal at the collector and ringing at the emitter Looks to be oscillating for some reason. maybe I will get some to time tomorrow. Thanks for the help
PostPosted: Jan Mon 09, 2017 9:03 pm
I'm sure you have checked this, but scope the electrolytics, it sure seems like one of them might be open in the power supply or/and agc line.
PostPosted: Jan Mon 09, 2017 10:56 pm
Steve I replaced the capacitor on the agc line (first thing I did) and jumper-ed the filter caps as I don't have the correct replacement with no improvement. Clearly its oscillating
where it should not. I think you logic is correct. Maybe I missed one. Time to start all over again and check each one ..... thanks
PostPosted: Jan Tue 10, 2017 3:12 am
Joel---I'm still wondering about the internal cap in 1st IFT. Just for curiousity, try jumpering the pins to which it is connected with a 100 pF or "tack" a 365 pF variable across it to see what effect it has when adjusted.
PostPosted: Jan Tue 10, 2017 7:29 am
John , you and Steve seem to be one step ahead of me. I disconnected the resistor feeding the base of the mixer to see if the mixer was the culprit that was oscillating. Once the bias was removed I checked the collector again and the signal was still present. That makes be believe that it is the IF section that is oscillating. No time today, will try later in the week.
Thanks for the help
PostPosted: Jan Wed 11, 2017 2:35 am
Please remember to let us know what you find---am sure interested to know !
Post New Topic Post Reply  [ 15 posts ]  Moderator: Dave Doughty
