It is currently Jul Fri 20, 2018 9:11 am
Post New Topic Post Reply  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: Audition Transistor Radio
PostPosted: Nov Mon 20, 2017 3:58 am
Trace the connections from the positive sides of the Electrolytic caps to find a common point. Most likely that is where the battery negative lead goes to. Don't worry about burning anything out with a temporary connection, just to see if the set works. Normally on these types of radios, battery positive goes to circuit ground.
PostPosted: Nov Mon 20, 2017 4:12 am
Thanks again Fifties !!.
PostPosted: Nov Sat 25, 2017 5:34 pm
OK, I finally got a chance to report on the Audition radio. I do have it fixed and playing nicely. The main problem other than the bad transistors was the Neg. battery lead was hooked up in the wrong place. I sure thank you all for your help. :D
Post New Topic Post Reply  [ 23 posts ]  Moderator: Dave Doughty Go to page Previous  1, 2
