It is currently Jun Wed 20, 2018 12:34 am
 Post subject: Has anyone heard of a Channel Master PM-6721??
PostPosted: Nov Wed 08, 2017 7:04 am
Just curious what a CM PM-6721 is, and how well does it perform...I cant find alot of info about it...which usually means its not such a good radio...even tho it has 19 transistors...
Kenny
 Post subject: Re: Has anyone heard of a Channel Master PM-6721??
PostPosted: Nov Wed 08, 2017 1:01 pm
A Google Image search turned up this picture. I'm not a fan of any radio that uses slider controls. Transistor count is not necessarily a measure of a radio's performance.
PostPosted: Nov Wed 08, 2017 11:39 pm
I am 100% with you on the sliders...I never did like them and still dont..but, for 8$ I had to have it..even if it dont work...it should have some good parts in there I could use..
This will be the first slider radio I think I have ever bought......
Kenny
PostPosted: Nov Thu 09, 2017 3:57 am
Most complaints with sliders is that they bind mechanically and do not slide smoothly. Often this occurs after cleaning with a non-lubricating cleaner, which tends to strip away the lubricant.
After cleaning, the use of DeOxit Fader Lube will restore their smooth mechanical operation. As long as the radio has enough mass, moving sliders shouldn't require that you stabilize it to do so.
In some cases, the binding is due to the plastic knob binding against the plastic housing - fixing this often requires more clever means.
PostPosted: Nov Thu 09, 2017 12:13 pm
Hong Kong made? There are several other radios just like yours - the Binatone and a Westminster model.
http://www.dustygizmos.com/arcpages/arcradio.htm - Binatone
https://www.ebay.com/itm/Westminster-Mu ... 2299915919 - Westminster
By the time your radio was made, Channel Master had moved on from selling rebadged Sanyos. I worked at a distributor that sold the Channel Master TVs (actually, Sanyo 91C_ _ stuff), table radios, and portable radios. We never sold the OPs radio model - the boss had dropped all but Channel Master TVs by then, about 1982-1983.
Brian
PostPosted: Nov Thu 09, 2017 11:02 pm
So this is not a channel master(Sanyo) radio at all..?
PostPosted: Nov Fri 10, 2017 9:01 pm
This POS is the worst radio I have bought in my entire life...I played it at the max 10 minutes, then broke it into pieces and trashed it..live and learn..
KNY
PostPosted: Nov Fri 10, 2017 11:24 pm
Here are two transistors out of this radio...no name, no type nothing...
And look at the cap's...NICE JOB
PostPosted: Nov Fri 10, 2017 11:29 pm
I have another piece of crap similar to that, sliding controls get stuck and bind, sound is terrible, reception sucks and it looks like a spider web inside with wires running in every direction, really sloppy workmanship.
I don't even know what brand it is, it just says Multi-Band on the front badge.
Rocco
PostPosted: Nov Sat 11, 2017 4:30 am
Mine is done and gone...I looked at ...and tried it out...and then destroyed it...Now its in the trash...........minus some parts I might need...
Kenny
PostPosted: Feb Tue 20, 2018 12:53 pm
I have this radio in the International Electronics version, model 1829, which I bought on eBay. It looks exactly the same as the Channel Master PM-6721. The slider controls on mine are OK and the radio works fine.
PostPosted: Feb Tue 20, 2018 4:21 pm
Found this Autotronic 752M today on eBay which appears to be almost identical to the Channel Master PM-6721 except for the cabinet and slider buttons and pushbuttons.
https://www.ebay.com/itm/MULTI-BAND-RAD ... SwzPFZ47hh
PostPosted: Feb Tue 20, 2018 7:11 pm
The Zenith TO's sure caused a bunch of copycats, eh? :wink:
Post New Topic Post Reply  [ 13 posts ]  Moderator: Dave Doughty
Users browsing this forum: GSD and 6 guests
