It is currently Aug Sat 18, 2018 1:50 pm
 Post subject: Raleigh Sound Master High Sensitivity All Transistor radio
PostPosted: Nov Tue 14, 2017 10:44 pm
Hi friends,
Please help with some information on a Raleigh Sound Master High Sensitivity All Transistor radio from 1965 (or so). It needs some parts to be replaced, including the two resistors pictured. We can't tell the value of these resistors because they've been burned to powder. There is no color coding on them to provide information. The information was printed on them, but is now unreadable. Please help by either 1) sharing a schematic for this radio or a source to get one or 2) looking at your schematic or if you own one of these radios, looking at the actual radio and report back to me what are the values of these two resistors.
As always, thank you very very much for any assistance you can provide!
Diane
P.S. Yes, we understand the need to find out what burned these in the first place. Full repair/restoration is in progress, if only we can find out the values of these resistors. Thanks again!
 Post subject: Re: Raleigh Sound Master High Sensitivity All Transistor rad
PostPosted: Nov Wed 15, 2017 12:49 am
That radio comes in several flavors, Goldstar, Nobility, Marlin, Sound Master, does the badge on the rear say BM 709 ?
Looks like your circuit board has a little different layout. I'm not surprised.
The resistor that blew could be the 220 ohm tied to one of the output transistors which I suspect has blown (shorted) that's a good place to start.
We've discussed this radio a few times in the past, here's the most recent with schematics.
http://antiqueradios.com/forums/viewtop ... 4&t=312837
Keep us posted on what you find, we can help you troubleshoot this.
Rocco
PostPosted: Nov Wed 15, 2017 12:59 am
The only thing on the back is a sticker that says "Made in Korea" and the R logo sticker. From what I can ascertain is that the model IS "Sound Master High Sensitivity All Transistor". The front says all of this. I either don't know how to go to the old forum, but I don't see any schematic on the link talking about the Nobility. I will take your answer to the technician and I will follow up shortly.
THANK YOU!
PostPosted: Nov Wed 15, 2017 1:05 am
220 ohm is a good place to start. I also forgot that there's another resistor that is blown. On the picture I sent with the original post, it's the tan-ish resistor just under the wide part of the arrow just above the yellow wire. Any ideas on the value of that one also?????????
Thanks again!
Diane
PostPosted: Nov Wed 15, 2017 1:30 am
It would probably be a good idea to replace the electrolytic capacitors, also---notice the blue one in lower left, the shrink label has split meaning that it may be shorted and has overheated maybe causing that resistor to burn. Appears to be in power supply line...
Good luck !
PostPosted: Nov Wed 15, 2017 1:31 am
Good point John, glad you mentioned that, were posting at the same time again, LOL
Diane just click on the link I posted in my previous reply, it should take you to the other thread.
The other possible blown resistor could be the 680 ohm.
This diagram may not be readable due to file size restrictions of this forum.
Rocco
PostPosted: Nov Wed 15, 2017 1:38 am
Nutzz. I did find that schematic eventually in the previous post, but it is different enough in the model that it doesn't answer the question. So far. Yes, thank you--he noticed the electrolytic and it'll all be replaced when we figure out the value of these resistors. I'm attaching a new photo that points to BOTH places that there is an unreadable capacitor. Keep the ideas coming, please!! (This appears to be a Sound Master variety. The picture from Radio Museum that was in the original post is the same model we're working on.)
Thanks again!
Diane
PostPosted: Nov Wed 15, 2017 1:50 am
Your radio appears to be different.
Note: the five electrolytic capacitors (shown with + & -) above in Rocco's schematic are all rated at 10V
Here is a doodle pad as a starting point if you want to draw your own schematic!
Large: http://a4.pbase.com/o9/56/215056/1/1649 ... titled.png
:) Greg.
PostPosted: Nov Wed 15, 2017 1:57 am
Thanks for posting that Greg, much better.
Yes, this radio looks to be a different layout.
Here's the diagram with the resistors in question
Rocco
PostPosted: Nov Wed 15, 2017 1:59 am
There is a transformer on the speaker on the Sound Master, so this is one thing that's causing some head scratching. Help??
Diane
PostPosted: Nov Wed 15, 2017 2:02 am
Sometimes small schematics are pasted underneath the top of the cabinet.
Greg
PostPosted: Nov Wed 15, 2017 2:04 am
if it has an output transformer then it's a totally different circuit, I have no info on that.
Rocco
PostPosted: Nov Wed 15, 2017 2:24 am
Out of curiosity... can you post a photo of the whole circuit board?
Image file restrictions here are width-800px by height-800px and file size-256Kb max
PostPosted: Nov Wed 15, 2017 5:40 am
Looks like germanium transistors in her set---the others mentioned were all "Super Silicon", I believe... And Raleigh did have their badge on one of those, too...
PostPosted: Nov Wed 15, 2017 5:45 pm
Thanks for the responses. Please keep 'em coming--we haven't solved the mystery quite yet.
One difference between ours and all the others posted so far is that there's a transformer between the audio output and the speaker, possibly a push-pull transformer. Maybe this is the difference between the "Sound Master" and the "Super Silicon" models????
As requested, here is a picture of the whole thing.
Thanks a million!
Diane
Post New Topic Post Reply  [ 15 posts ]  Moderator: Dave Doughty
