It is currently Dec Sat 15, 2018 12:40 pm
 Post subject: case of radio chassis - how to wire
PostPosted: Nov Wed 22, 2017 7:00 pm
About 10 years ago I purchased a case of these Starbuck radio chassis and quite frankly forgot about them.
Now that I found them in my basement again, I am thinking about several projects.
However no instructions and I want to make sure I connect these correctly since they are 120v and not 9 v.
The speaker plug in and the transformer plug in are obvious since they are unique plugs.
I am thinking the power cord connects to the red and black wires and the light attached to the brown and blue off the transformer because of matching wires.
Google came up with nothing.
What do you guys think?
Art's Antique Radio Collection - A work in progress
http://www.myantiqueradio.com
 Post subject: Re: case of radio chassis - how to wire
PostPosted: Nov Wed 22, 2017 8:43 pm
Do Not Connect 120 volts AC to the red and black wires!
Not sure what those wires were used for but that's the low voltage side of the step down transformer. Probably around 6 - 9 Volts with a center tap.
The 120 volt input of the transformer is on the opposite side (Brown, Blue)
The lamp is not required for the radio to function. You can add that later to your project.
You can check the resistance of the 120 volt side with an ohm meter, a typical 9 volt transformer of that size is usually 200 ohms or higher.
Looks like this board uses a common AM/FM chip TA2003p
http://www.alldatasheet.com/datasheet-p ... 2003P.html
with a separate audio IC
Rocco
PostPosted: Nov Wed 22, 2017 8:59 pm
so to make sure I understand
Power cord connects to the brown and blue of the transformer
Maybe the red and black are for the bulb?
PostPosted: Nov Wed 22, 2017 9:07 pm
The bulb looks to be 120 volt, can you confirm?
it has brown and blue wires, same as the 120 volt line.
so, not likely connected to red and black wires, that's only 9 volts AC
Rocco
PostPosted: Nov Wed 22, 2017 9:25 pm
So what would the red and black wires connect to?
You can probably test the board with a nine volt battery, connected to the circuit side of the rectifier Diodes.
PostPosted: Nov Wed 22, 2017 9:45 pm
Good idea fifties, even 4 AA's (6 volt) would work.
the AM/FM chip is rated at 7 volts max so be careful
what are the voltage ratings on the E-caps of this board?
Rocco
PostPosted: Nov Wed 22, 2017 9:53 pm
we may never know the answer to that, could have been power to a dial lamp or another accessory.
Rocco
PostPosted: Nov Wed 22, 2017 9:58 pm
The red and black wires appear to be coming from a switch on the volume control, then pass through (but do not connect to) holes near the transformer secondary connections. I suspect they are to be wired to interrupt the 120 volt input to the transformer primary and bulb. Where is the bulb supposed to be mounted in the cabinet?
T1 and C10 appear to be missing.
PostPosted: Nov Wed 22, 2017 10:10 pm
I noticed T1 and C10 were missing as well.
but now I see that the red and black are not soldered to the board, they go straight to the switch.
Good eye Dave
Rocco
PostPosted: Nov Wed 22, 2017 10:21 pm
No cabinets
and What is T1 and C10?
You lost me
PostPosted: Nov Wed 22, 2017 10:41 pm
T1 would be a chrome metal IF coil same as the other one on the board and C10 would be a small ceramic cap similar to C19 Circled in red below-
It may be optional, the radio could still work without those parts.
Rocco
PostPosted: Nov Thu 23, 2017 3:09 am
I will try firing one of these up over the weekend after I stuff myself with turkey
PostPosted: Nov Thu 23, 2017 7:34 am
That other can looks to have a red core, as in it being an oscillator coil. Could be that the chip doesn't need an external IF filter, which is why they left it and the cap out.
PostPosted: Nov Thu 23, 2017 12:11 pm
oldradio99 wrote:
No cabinets
Sorry, I must have been thinking about another thread.
I agree that T1 and C10 might not be needed.
PostPosted: Nov Fri 24, 2017 6:17 pm
Got brave this morning!
Wired the power cord to the brown and blue of the transformer.
Plugged the cord into my variac and brought it up slowly.
Radio started playing at 60v AC.
Discovered the radio is AM/FM using the switch on the back. Decent reception and playing for such a basic set.
I connected the bulb directly to the cord and it is a 110v bulb.
So what that leaves is that black and red wire coming off the volume control.
With the radio playing, no AC or DC voltage between the red and black.
With radio off there is some variable resistance as the volume knob is turned.
Cant open the volume control without breaking the plastic back. Glued heavily. But if I have to open it I can.
I wonder if there is some way to wire the bulb into the AC and these wires to control the brightness? Is that a crazy idea?
On the red and black wires, the holes that the wires go through are marked AC.
Having the bub direct to the cord means its on all the time.
Thanks.
PostPosted: Nov Fri 24, 2017 6:57 pm
I GOT IT!
The red and black wires control the light being on or off
So here is how it all gets wired
1. One side of the AC plug gets connected to blue wire form the transformer and the red wire marked AC
2. Connect the other wide of the AC plug to the brown wire from the transformer and to the brown wire from the lamp.
3. Connect the Blue wire from the lamp to the Black wire marked AC
Plug the speaker into HC-2
Plug the transformer into HC-1
Now that I have it, it seems so simple.
Thanks to the group.
Art
Post New Topic Post Reply  [ 17 posts ]  Moderator: Dave Doughty
