It is currently Oct Mon 15, 2018 11:56 am
 Post subject: Need a diagram for a Channel Master 6528 please.
PostPosted: Nov Sat 25, 2017 6:30 am
If someone has this I really need it...and thanks for all your help...
Kenny KE4HVE
 Post subject: Re: Need a diagram for a Channel Master 6528 please.
PostPosted: Nov Sat 25, 2017 3:18 pm
Sanyo 6C-19
Manufactured by Sanyo and identical to their model 6C-19
Schematic: http://www.kevinchant.com/uploads/7/1/0 ... /6c-19.pdf
I use AA batteries from Ikea (slightly smaller in length) and also file the top down a little.
A lot of modern AA's are just too tight a fit, and on occasion they will bust the case. I have this trouble with a couple of ITT radios in my c̶o̶l̶l̶e̶c̶t̶i̶o̶n̶ queue. Lol.
Ikea AA's: http://www.ikea.com/us/en/catalog/products/50240502/
oh... Model 6528A badged as 6 transistor 3 i.f.
image: https://i.pinimg.com/originals/59/93/ce ... 126e74.jpg
Three page Service manual for 6C-19A http://www.kevinchant.com/uploads/7/1/0 ... 6c-19a.pdf
for the sake of completeness... :) suffix→ B model 6C-19B
http://www.kevinchant.com/uploads/7/1/0 ... 6c-19b.pdf
PostPosted: Nov Sun 26, 2017 2:19 am
Thank you very much...2 questions, where is C11? and what does that adjustable pot that is by the 2nd IF do?
Again thanks..
Kenny
PostPosted: Nov Sun 26, 2017 3:16 am
Kenny, if you have CM model 6528 without a suffix letter then Sanyo 6C-19 is your schematic.
As 6C-19 is a schematic only...
...the other two with suffix A and B (with no doubt minor circuit changes) were posted for main component reference and alignment instructions.
C11 (ceramic capacitor) is shown on the trace diagram and on the schematics with an asterisk pointing to two different values. Leave it alone (it should be OK)... or if you need to, replace it with what you find in your radio. It is located in the region of TR3 and TR5
The (variable) semi-fixed resistor R15 (vr) is mentioned in the alignment procedure.
PostPosted: Nov Sun 26, 2017 3:46 am
You are right, I did not see the a and b diagrams....and sorry for the mix up...my fault..
