It is currently May Fri 25, 2018 1:26 pm
 Post subject: Need a diagram for a Grundig Transworld Ambassador - Model
PostPosted: Nov Sat 25, 2017 6:18 pm
Looking for any info on this 14 transistor multi band model.
From the stamp inside seems to have been made around May 1965.
A circuit diagram would be really helpful. :)
 Post subject: Re: Need a diagram for a Grundig Transworld Ambassador - Mod
PostPosted: Nov Sat 25, 2017 7:13 pm
Shaun, this is as close as I can find.
Grundig Concert Boy 200 http://85.144.192.2/nvhr/Grundig_Concertboy200.pdf
Most of the trimmers in upper, lower case and Roman numerals should be the same.
Some translation required.
Concert Boy Transistor 200 https://www.doctsf.com/grandlivre/fiche ... 920&ori=ps
others:
Concert Boy Transistor 201 https://www.doctsf.com/grandlivre/fiche ... 921&ori=ps
Concert Boy 202 https://www.doctsf.com/grandlivre/fiche ... 538&ori=ps
oh... The doctsf.com (télégraphie sans fil) pdf's are untagged, you may have to add .pdf to the end of the downloaded file!
Trans-world Ambassador.
Concert-Boy transistor 200
PostPosted: Nov Sat 25, 2017 9:27 pm
Thank you Greg,
They do look extremely similar so I am sure that the PDF will be a big help.
I will have to try Google translate to see what it does to the text. Sometimes it's very amusing :)
Post New Topic Post Reply  [ 3 posts ]  Moderator: Dave Doughty
