It is currently Oct Wed 17, 2018 11:35 am
 Post subject: Sony ICF 2010 DC Plug Dimensions mm OD
PostPosted: Dec Mon 04, 2017 7:07 pm
Hello to all there.
I have a Sony ICF-2010.
I need to know the proper size of plug (mm OD inner and outp), to use with this radio.
I have to buy one to put the Radio Shack power adapter on its tip.
In advance, thank you all for help.
73 Gergi
 Post subject: Re: Sony ICF 2010 DC Plug Dimensions mm OD
PostPosted: Dec Mon 04, 2017 10:58 pm
First welcome to the forums.
From my understanding it is this type of plug...
Discussed here... https://groups.google.com/forum/#!topic ... BJuz-oU5G0
It is generally listed as 4 mm OD, 1.7 mm ID, 9.5 mm length
Appears to be these... https://www.mouser.com/ProductDetail/CU ... kUdg%3d%3d
Datasheet here... http://www.mouser.com/ds/2/670/pp-013-1154962.pdf
Note: There was some discussion about the center conductor being the negative connection. I cannot confirm this.
It looks like it might be Radio shack Adaptaplug B https://www.radioshack.com/products/rad ... aptaplug-b
Curtis Eickerman
PostPosted: Dec Tue 05, 2017 4:12 am
...but I am finding that the centre pin has two sizes as well.
Cheers - Martin ZL2MC
PostPosted: Dec Tue 05, 2017 5:57 am
What center pin? You mean in the radio? If so, then the P/S that originally came with it would have to have had one of two different connectors. Not something that I would expect from Sony (or really any other maker).
PostPosted: Dec Tue 05, 2017 1:33 pm
Hi there.
Thank you all for answering.
I'm going to buy some of this on ebay to prove what works: https://www.ebay.com/itm/8in1-Universal ... 0005.m1851
PostPosted: Dec Tue 05, 2017 3:16 pm
georgi wrote:
With that selection it would appear to be their item G.
It would be helpful for future reference if you posted your end result when you acquire this. In the prior thread I referenced, the original poster no doubt eventually proved beyond a doubt which was the correct plug, but they never posted their final result. I find that very frustrating.
Curtis Eickerman
PostPosted: Dec Tue 05, 2017 3:34 pm
Ok Curtis.
Or maybe a type C, anyway I will come here again and publish what works, without forgetting that the center pin is negative.
Thanks again to all for your collaboration.
PostPosted: Dec Tue 05, 2017 6:10 pm
If those colors are universal, all my Sony radios use the green one "B" 6X3
Center pin is "Negative"
it's possible the ICF-2010 is different, I don't have one to confirm.
Rocco
PostPosted: Dec Tue 05, 2017 8:04 pm
Well, of course I meant the centre pin in the radio - what else. Not in that particular radio, but sockets in general. You have to assume that as he is looking for the plug then he hasn't got the power supply to compare
Here is a pic from our catalogue of two almost identical plugs with different sizes of centre socket.
Although both outers are 5.5mm, the centre socket is 2.1 or 2.5mm diameter.
PostPosted: Dec Wed 06, 2017 12:20 am
The OD is in the area of 4 to 5 millimeters, ID, about 2mm, shaft length 10mm. I'm relying on damn near 73 Y.O. orbs, and a worn ruler, so don't consider this as lab grade measurements. The outer metal is positive, inner is negative. Here's a scan;
PostPosted: Dec Wed 06, 2017 1:06 am
Well, I just measured my green adapter and it's 4.5 MM OD, Not 6x3 so it must be a different set than the ebay ones in the photo.
Our measurements do coincide for a typical Sony power plug.
Rocco
PostPosted: Dec Sat 09, 2017 9:15 pm
Well come on then, what is/was the answer - don't keep us all in suspense..... :)
PostPosted: Dec Sat 09, 2017 9:24 pm
Sorry Marty, but if we told ya, we'd haveta...Well, you know the rest... :wink:
Post New Topic Post Reply  [ 13 posts ]  Moderator: Dave Doughty
