It is currently Jul Sun 22, 2018 4:09 am
 Post subject: RCA Strato World Mark One Disassembly
PostPosted: Dec Tue 05, 2017 4:51 pm
I recently purchased a Strato World Mark One (ca. 1969) in mechanically-damaged but generally working condition. This model of radio is completely alien to me- I'm a longtime collector of Zenith TO tube and transistor portables and have a couple of RCA Strato World (tube type) sets in my collection, but have never heard of this particular model. It appears to have been aimed at the same market as the Zenith TO 7000. It is a Japanese-made multiband radio with some decent features like bandspread, tuning meter, and BFO, but the map light is nonfunctional (the light bulbs themselves test OK) so I need to pull the chassis out of its case to examine the lamp switch.
Haven't been able to locate any service info on this set, but that's not of immediate concern to me since the radio functions themselves seem to be in good shape on all bands. The sticking point is: how do I extract the chassis from the plastic case? It appears that it is retained by three long hex posts and one phillips-head screw; but I am concerned that there may be some subtlety that I am missing. Does anyone have any experience at tearing one of these radios apart?
 Post subject: Re: RCA Strato World Mark One Disassembly
PostPosted: Dec Wed 06, 2017 12:40 am
Any access to the switch to probe for continuity, voltage on the contacts or the ability to short the switch to see if that lights the bulb? The wire(s) may be pinched so check the lamp socket (unpowered) both sides to ground for continuity. Only one side should be grounded, of course. In the case there's voltage at the socket, make sure the center lug makes contact to the lamp's solder button.
In my TO-3000, the lamp has it's own single D-cell in the battery pack for power, so there's another angle to look at to make sure all the holder contacts and cells are good. I don't know how it's wired up in the Strato World.
It'd be great not to have to disassemble just to get the dial lamp going!
-Ed
PostPosted: Dec Wed 06, 2017 2:46 am
-Ed
The SW dial is lit by six grain of wheat bulbs. There are two bulbs for "low level" lighting and four more to illuminate the clear plastic relief world map superimposed on the dial scale; two momentary pushbuttons select between "dial" and "SW map" lighting. There is at least one additional bulb that illuminates the separate Broadcast AM-FM circular dial scale. My guess is that there are actually two bulbs on this latter scale, with one burned out (only the right side of the dial is lit up, which is probably not what the manufacturer intended).
Presumably the flip-up shortwave dial scale and the circular AM/FM dial lamps are actuated by the same "dial light" pushbutton. So, my guess at this point is that the ground wire in the three-wire bundle that goes through the hollow lid pivot to the two sets of SW dial maps has opened up- that would explain why neither set of lights work (even though all bulbs are good). Unfortunately, to repair this wire bundle the chassis has to come out of the case.
This is a pretty cool radio... unlike the transistorized Zenith TO series, this set uses three separate ferrite-rod loop antennas for longwave, standard broadcast, and shortwave AM. There is a telescoping rod antenna but it is only used for FM.
PostPosted: Dec Wed 06, 2017 6:28 pm
Perhaps this old thread will be of some interest:
viewtopic.php?f=4&t=94688
I posted this 9 years ago and I'm sorry that I don't remember how I got the chassis out of its case. I do remember that it was somewhat of a challenge, however. I sold the radio to a friend who still has it and says it still works fine.
PostPosted: Dec Thu 07, 2017 12:47 am
There's sure a lot more lamps in there than I guessed!
Generally, when I yank an unknown chassis, I loosen the most likely fasteners and lift it a bit to see what comes up or stays put. Some might be a subassembly attached to the main chassis, and those screws should remain. After some gentle or less gentle (as frustration dictates) and watching for wires... but I think we've all been down that road! I hate taking the chassis out of my ZTO 3000, and I need to to fix the earphone jack. Ugh!
-Ed
PostPosted: Dec Thu 07, 2017 9:07 am
Thanks to all who responded. I managed to get the chassis out of its case with really no trouble... after I figured out "the trick".
The chassis is held to the plastic case by three hex posts and several small phillips-head screws. The factory thoughtfully marked these with a dab of red lacquer so that it was fairly obvious which ones needed to come out. However, removing all of these threaded fasteners in the back of the set still saw the chassis being held fast.
"The trick", as it turned out, was a small phillips screw in a front panel recess next to the tuning knob shaft. The large tuning knob skirt normally covers this screw, so it isn't very obvious. Removing this screw freed the chassis and allowed it to be pulled out of the case, after having depressed all of the band-select pushbuttons enough to clear the plastic backing bar behind them. There was enough of a service loop on the speaker and tuning meter wires to make unsoldering them not necessary, at least for my immediate objectives.
For the record, I did discover that the circular standard broadcast AM/FM dial was supposed to be lit by two grain-of-wheat lamps- but the left one was in fact burned out. I'm thinking about biting the bullet and replacing all eight lamps in the set, just because I dread ever having to open up this set again.
Restoration of this set (re-capping, alignment) seems to be out of the question without documentation.
PostPosted: Dec Mon 25, 2017 8:57 am
OK, got the bad light bulbs replaced and the set reassembled. The power wire that went to the "world map illumination feature" was broken off at the switch; a bit of solder fixed that.
I used 12V grain of wheat replacement dial lamps; their light output level seems to be the same as that of the original bulbs, all running on 9V. Operating the bulbs well under their rated voltage probably explains why only two of the eight bulbs were burned out after approximately 48 years of use.
FWIW, this set has an interesting approach to the dial lights. When the set is being used in AC-operated mode, the dial lights are on as long as the set is turned on. In battery-op mode, it is necessary to press the "dial light" button to get these lamps to illuminate.
There are two separate dials: a circular one for standard broadcast AM and FM; and a sliderule type in the flip-up front cover for all other bands. The appropriate dial is illuminated according to the band selected, with the unused one left dark. This is the case whether the set is operated on AC or battery.
The "map light" feature is only actuated when the front-panel "map light" button is pressed.
Bulb replacement is pretty straightforward and does not require removal of the chassis from the case.
This is a great-performing radio although the workmanship does not seem to equal that of the earlier transistor Zenith Trans Oceanics like the 1000 or 3000. I'd still like to find a service manual for it, if one exists.
Post New Topic Post Reply  [ 7 posts ]  Moderator: Dave Doughty
