It is currently Dec Wed 12, 2018 5:10 pm
Post New Topic Post Reply  [ 1 post ]
 Post subject: I need help on a Channel Master 6519 alignment
PostPosted: Feb Thu 15, 2018 12:18 am
Hello all...if someone could look at the alignment instructions for the 6519, I think something is wrong with the directions...the diagram I have (Sams) does not show the BC coil adjustment right..It is showing A11 as the SW coil adjustment..and I know from other Channel Master radios that L1(the far left coil) is the coil for the BC band..and should use A11 to adjust the BC band coil, not the SW band..Does anyone see what Im talking about..???
Also there is no mention to the adjustment of L2...which in other radios that is the coil to adjust the Oscillator for the SW band (yellow coil). Should the A11 adjustment be pointing to the L2 coil instead of the far left coil on the ferrite bar, which is L1.
So confusing I am..
Kenny KE4HVE...
Post New Topic Post Reply  [ 1 post ]  Moderator: Dave Doughty
