It is currently Jun Sat 23, 2018 6:30 pm
 Post subject: Duplicate radio, different power supply.
PostPosted: Feb Fri 16, 2018 6:47 pm
I just found a duplicate radio to one I already own, a Sylvania 4P14, but it has a different battery arrangement. The first Sylvania I got was a 5P series, had a messed up battery holder for 4 AA size cells. I rebuilt it,and the radio played well. Then I found a 4P14 with no battery holder and had to constructabattery holderfrom scratch. It also plays Welkom the 6 volts. Now I bought another 4P14, but it has a long rectangular 9 volt battery in it, long dead, but not leaking. I am somewhat confused on why the 5P?? Set had4AA cells and the earlier 4P14 runs off 9 volts. Now I have a project to try to duplicate the 9 volt battery for the recent acquisition.
Anyone else run across this kind of variation?
 Post subject: Re: Duplicate radio, different power supply.
PostPosted: Feb Fri 16, 2018 8:07 pm
Sylvania 4P14 was manufactured to run of 9Volts
What size is your... long rectangular 9 volt battery?
Sylvania 5P*** models were manufactured to run of 6Volts
image: https://i.ebayimg.com/images/g/D-IAAOSw ... -l1600.jpg
4P14 image: https://i.ebayimg.com/images/g/ytEAAOSw ... -l1600.jpg
Posting photos to a forum thread.
The skinny: viewtopic.php?p=2717120#p2717120
PostPosted: Feb Fri 16, 2018 8:35 pm
I do not have the radio in front of me, but would guess it is about 3/4 inch thick by 1 inch deep and around 3/12 to 4 inches long with a snap on each end. The radio would not accommodate a cylindrical 9 volt.
PostPosted: Feb Fri 16, 2018 11:03 pm
I have a 4P19; these sets were made to be powered by 9 volts, and the battery compartment is big enough to park a smart car in... :wink:
I would guess that the 4 AA cell holder was put in by someone who either didn't know how to change the battery snap connectors, or didn't want to pay for a nine volt battery. I changed mine sometime ago, to a nine volt snap connector;
PostPosted: Feb Sat 17, 2018 3:10 am
Interesting, the 4 cell AA holder in the 5P ?? was made with cardboard tubes, with metal ends. The battery placement diagram was glued to the tubes so I am sure it was original. The tubes even had " Burgess " brand batteries, the ones with the stripped paint scheme. Unfortunately they had leaked and swelled and I couldn't salvage either the batteries or the tubes. The holder I built for the 5P?? Radio was a replica of the factory one. 4P14 mimicked the factory one in the other radio. I made the metal ends and constructed the twin cardboard tubes too. Now that I know the 4P14 uses that strange battery, I can construct a replica using photo copies of the original one, and stuff it with modern cells. Should be easier than making the cardboard and metal one I made.
Oh, and I did have a 4P19 radio too, it was one of the worst performers I ever had with that weird regenerative detector stage, just way too quirky to be reliable.
PostPosted: Feb Sat 17, 2018 7:51 am
I have a couple of the round batteries. If you want one to re-stuff, your's for postage. Just PM me. I'm not sure how you could open it up though, W/O destroying it.
PostPosted: Feb Sat 17, 2018 5:32 pm
Fifties,
The round ones won't fit in the 4P14 I don't think. I would try rebuilding them by using a dremel tool and grinding the crimped end to be able to clean out the innards. It would be a messy procedure and might not be worth the effort. There are sellers of vintage looking labels that could be put on batteries built into pvc tubes that could work.
I still haven't identified the one in my radio, and because I'm not home, can't look at it to get more information.
Thanks for the offer.
Bob
PostPosted: Feb Sat 17, 2018 6:05 pm
It's probably the Larger and more economical Eveready 246 as mentioned on the rear cover of Richard's 4P19 above.
Neat advert for 4P19... LIFE magazine January 1961
image: https://books.google.co.uk/books/conten ... NIA&w=1280
PostPosted: Feb Sat 17, 2018 6:28 pm
It's not the 246, which is thicker and mine has a snap on each end.
PostPosted: Feb Sat 17, 2018 8:07 pm
So I just looked at the original EBay listing, and enlarged the interior photo as best as possible. It looks like an eveready # 213 or 215 battery. Don't know for sure because the picture was at an angle and I am viewing it with a not-so-smart phone.
PostPosted: Feb Sat 17, 2018 8:21 pm
I think I have it, a # 2362 battery, whew!
PostPosted: Feb Sat 17, 2018 9:48 pm
Very good Bob.
It's listed here as 2364!
https://www.radiomuseum.org/r/eveready_ ... _2364.html
PostPosted: Feb Sun 18, 2018 12:15 am
Well, I have never seen a radio that used this battery, or even saw the battery used or advertised anywhere.
It's truly an oddity, they must have had a very small usage and were put out of production. So now I have a relatively scarce radio, with an unobtanium battery, cool !
As soon as I get home I will start work on replicating the battery to the best of my ability. I suppose I could just fab up a sleeve to hold a standard modern battery, but what fun would that be ? Glad I finally figured it out, with everybody's help and encouragement.
Two more days soaking up the Mexican sun, then back to frigid Michigan.....yuk.
Bob
PostPosted: Mar Mon 12, 2018 3:41 pm
Finally took photos of the battery in the Sylvania. Going to try to photocopy the outside, then build a pack that looks stock. That battery is unobtanium these days. Lucky to even find one in decent condition to look at.
PS: I powered up the radio from my bench supply, it plays fine, won't even have to change electrolytic caps, just clean up the volume and tuning controls .
Post New Topic Post Reply  [ 14 posts ]  Moderator: Dave Doughty
