It is currently Sep Sat 22, 2018 4:06 pm
 Post subject: Motorola X60N project...
PostPosted: Mar Mon 05, 2018 3:14 am
Hello All,
This popped up on Ebay with a reasonable "Buy It Now" and free shipping and thought it might be an interesting set to play with...
Larger than I thought from pictures. It arrived complete with 2-"AA" batteries and only had very slight audio "hiss" when turned on. Using another nearby radio, the oscillator proved "active"...
The power input filter cap appears to be almost "disintegrated" within it's vinyl wrap which is covered in tiny "blisters" and dried electrolyte residue is all around it---also PCB trace beneath appears discolored. Tried jumping the audio coupling cap with good part and only heard "clicking" in speaker as leads made contact, so will replace all electrolytics before proceeding. The audio output is OTL and uses a center-tapped speaker like many earlier RCA sets.
Ebay pic below---more to come !
Anyone else have one ?
 Post subject: Re: Motorola X60N project...
PostPosted: Mar Tue 06, 2018 3:40 am
It's now working ! But the electrolytics weren't the problem...
No time left tonight for details, so stay tuned !
PostPosted: Mar Wed 07, 2018 4:32 am
Cosmetics detail cleaned and the tuning dial/magnifier polished this evening---more to come !
PostPosted: Mar Wed 07, 2018 5:46 am
Hey John, that seems to be a rarity. In fact my Bunis Guide shows an X60 E & W (made in 1965), but no N . Values $10-$15.
PostPosted: Mar Thu 08, 2018 3:00 am
Hey Richard---got it completed tonight and hope to post pics in the next couple days... The label is still inside back cover and shows model #. Seems to work very well after recap & repair without any tweaking...
PostPosted: Mar Fri 09, 2018 2:22 am
I have the E model (Ebony? - it's dark brown, almost black). I agree it's a good performer - mine did need a bit of tweaking.
While the 'Eight Transistor' graphic on mine appears to have less damage than in that photo, the Motorola graphic is badly corroded.
One day I'll get around to cleaning up the plates and reproducing the graphics.
Joe
PostPosted: Mar Fri 09, 2018 2:37 am
Hey Joe---when you are ready, I can try and get some good "straight-on" pics of the Motorola trim-plate. Just let me know ! Does yours also have to be turned up to max to get "listenable" volume on weaker signals ??? "Normal" and stronger signals are fine with plenty of reserve audio...
Finishing touches on this 1965 set and project detail write-up tonight...
The front of speaker was really dirty, so very gently "brushed off" with a clean Q-tip and carefully used vacuum cleaner nozzle at a safe distance to remove residue. The original speaker wiring was solid-conductor, so replaced with longer lengths of stranded 28 gauge Teflon insulated wire for easier servicing in the future. The earphone jack contacts were somewhat corroded, so removed its wiring and added a jumper to PCB for bypass.
Had to remove the tuning knob for cleaning and when re-installing, noticed that the dialcord was "crossed" on the variable cap pulley---removed ends and corrected which resulted in smoother "action"...
The battery holder was missing the lower contact pair and previous owner had simply used a piece of wire in its place. Had a damaged Toshiba holder in parts bin and was able to salvage a good contact assembly from it which fit and worked fine---see pic below...
Replacing electrolytics didn't restore operation---after troubleshooting, discovered that the ferrite-rod antenna input winding was open. Found the break and fortunately had enough wire to form a small hook to attach to winding stub and solder. The coil at other end had come loose from rod, so used tip of soldering iron to carefully melt and flow the green wax (smelled like a melted crayon) around edge to secure. Radio worked fine afterward---very good sensitivity/selectivity all across band. Sound decent, but volume level on weaker signals just "listenable" at maximum. Was very surprised during "tweak session" to find that the ANT trimmer and all IF's were pretty much "dead-on" as they were---and the volume control was "noise-free"...
Project pics below in two "installments"... The last pic shows a Zenith Royal 500H with the X60N for size comparison.
As always, like to hear from others who have had experiences with the radios featured in projects.
PostPosted: Mar Fri 09, 2018 2:38 am
Here are the remaining project pics---please see previous post for first group...
PostPosted: Mar Fri 09, 2018 2:44 am
I confused by the three connections on the mono speaker. :?
PostPosted: Mar Fri 09, 2018 2:47 am
Hey Marty---this radio has no audio output transformer and uses a "center-tapped" speaker voice-coil instead like RCA did a few years previous. Will post schematic if interested...
PostPosted: Mar Fri 09, 2018 3:44 am
John:
Yes, I find it does need to be turned up more than usual on weaker signals. Just discovered it has developed an intermittent problem with the audio though, so it may be related. I recapped this one years ago - guess it needs to be revisited. It'll have to go to the back of the line, though, as I have far too much else on the go.
I have enough of the graphic that it can be restored. In fact, the typeface is plain enough that I will probably be able to find the correct font and replicate it that way. Thanks for the offer though.
Joe
PostPosted: Mar Fri 09, 2018 1:47 pm
That's a neat little restoration!
PostPosted: Mar Sat 10, 2018 12:35 am
Thanks Metzman !
PostPosted: Mar Sat 10, 2018 10:51 pm
Another sweet thorough job. Wow
PostPosted: Mar Sun 11, 2018 7:30 am
Thanks CJ Design !
Post New Topic Post Reply  [ 15 posts ]  Moderator: Dave Doughty
Users browsing this forum: 2vlad and 4 guests
