Page 1 of 1
[ 7 posts ] |
| Author |
Beefus
Post subject: Need Help with transistor SCA radio Posted: May Sat 18, 2013 10:38 pm |
| Member |
Joined: Aug Tue 21, 2007 10:03 pm Posts: 26 Location: Cincinnati, Ohio
Hi,
I need some help from the transistor radio experts out there.
I volunteered (don't get paid) to repair radios for the Radio Reading Services in Cincinnati, Ohio. These radios are used by blind people to receive local information that is transmitted as an SCA signal by educational station WGUC on 90.9 FM.
I would be interested in any service information for the radio made by a Chinese company called "Success model ML-922" or model "HL-922".
Many of the radios I have received of this model are missing some or all of the screws that secure the back case to the front.
I have included a picture of the screw and one of the radios.
I need help with a technical description of the screw (eg. 4-40 x 2" philips head) that I need so that I can search eBay and various companies for pricing. The metric screw dimensions are 30mm length, thread width about 2.85mm, and head is a Philips with width about 4.8mm.
I spent some time on the internet trying to figure out the specs for the type of screw I need but didn't make much progress. It kinda appears to be something like a 3mm x 30mm pan head, but how is the taper defined? It is certainly not a machine screw as it screws into plastic.
If you know how to specify the screw and perhaps some suggestions where to buy I would be grateful.
I tried a google search on the company and model but didn't find anything.
Thanks for reading this.
Jack, WB8BFS
| Attachments: |
| Top |
bills
Post subject: Re: Need Help with transistor SCA radio Posted: May Sat 18, 2013 11:21 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1177 Location: Baldwin Park Ca.
| Top |
Beefus
Post subject: Re: Need Help with transistor SCA radio Posted: May Sat 18, 2013 11:38 pm |
| Member |
Bills,
Thanks for the info. I tried McMaster-Carr earlier today (same page actually) but all their stuff appears to be non metric and they don't have the length that I need.
Jack
| Top |
PBPP
Post subject: Re: Need Help with transistor SCA radio Posted: May Sun 19, 2013 12:12 am |
Joined: Jun Tue 21, 2011 8:27 pm Posts: 2087 Location: Virginia
Hi Jack,
Referring to this as a 4-40 is a misnomer. -- That would indicate it is a machine screw. I've always seen them called 'sheet metal' screws.
Is there a Mom & Pop hardware store close by? The big box stores won't have the expertise to find what you're looking for, but the smaller ones with an old-timer can probably help.
I'll poke around my junk box and see if I have a few that are close.
~ Mitch ~
| Top |
Beefus
Post subject: Re: Need Help with transistor SCA radio Posted: May Sun 19, 2013 12:23 am |
| Member |
Mitch,
Thanks for the reply. I am planning to go to one of the Hobby shops to see if they might be able to help. When I quoted the (4-40 x 2") I was trying to express that I need to know the size of the screw in the picture, I only used 4-40 as an example. I believe it to be metric but don't know what the description (xx by xx by xx) is of the screw in the picture.
Bill's post about McMaster-Carr shows screws intended to be used with plastic but their screws are not metric and are not long enough.
Jack
| Top |
bills
Post subject: Re: Need Help with transistor SCA radio Posted: May Sun 19, 2013 4:40 am |
| Member |
If you check the links I posted you will indeed see that they have metric. scroll down and you will see
_________________ KI6JUV
| Top |
Beefus
Post subject: Re: Need Help with transistor SCA radio Posted: May Sun 19, 2013 5:43 am |
| Member |
Bill,
You are correct.... Guess I did not scroll down far enough. Unfortunately the screws they have are a max of 14mm and I need 30mm, but now I know the screw size and thread is M2.63 x 1.06.
Thanks for the help.
Jack
| Top |
Users browsing this forum: psbot [Picsearch] and 2 guests |
