It is currently May Thu 23, 2013 10:51 am
Post New Topic Post Reply  [ 45 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Schematic for Panasonic RX-DT690 ?
PostPosted: Nov Sat 05, 2011 3:18 pm
I did a mod to a boombox once to add an input for my mp3 player. I bought an 1/8" stereo jack from Radio Shack. The jack was a POS out of the package so I got another one. that one was a POS too. I should have used a multimeter from the start to double check the part before installing it. I would have saved me some troubleshooting. So check your parts from Radio shack. :lol:
PostPosted: Nov Tue 15, 2011 5:28 am
geoffley-
I'm glad you found it helpful. Apparently you're not the only one- there have now been 969 downloads of that file. Thanks for the update on Supahslime's method, too.
Alltare
geoffley wrote:
Hi everyone, I registered especially to thank you for the great information here. I was looking to mod my RX-DT680 as per your instructions, but chanced across Supahslime's tip. I would like to confirm to you that it works perfectly. I am actually using a blank audio track burned to Cd, set to repeat. You can get silent audio tracks here http://duramecho.com/Misc/SilentCd/index.html among other places. I now use my RX-DT680 with an Apple AirPort Express as a portable, wireless playback device from my iTunes library on may Mac (kind of like an iTunes equivalent of a Logitech Boom). Thanks again.
PostPosted: Jan Sat 21, 2012 7:19 am
I really hope someone can tell me what the differences are between the Panasonic RX-DT680 and the RX-DT690. I had a 690 for decades and loved it. I made the mistake of loaning it to a friend who wanted to use it at her church, and it "disappeared" while it was there. I'm now trying to replace it, but am having zero luck finding one in excellent condition like the one I lost. I did find a 680 model, but can't seem to find any documentation that tells me how it's different from my original 690 model. Can anyone here help me by providing answers? How do the 680 and 690 models differ? Thanks much!
PostPosted: Jan Wed 25, 2012 6:08 am
Hi all
Thanks to alltare and others for this very handy mod. I recently bought this radio to take out to parks, the beach etc but was disappointed to find it doesn't have an aux input from factory (who uses tapes and cd's these days? haha).I performed the mod, took a little longer than I expected after a couple of hiccups but now I have a 3.5mm closed circuit jack flush mounted on the rear of the unit.
The only minor problem is I have a quiet background noise when I have a source plugged into the newly installed input on the back. You can only hear it when there is no music and the volume is at moderate levels. I can't pinpoint where the noise is coming from, it only happens when you plug something in. When nothing is plugged in the circuit from the tape deck works as it should with no interference... if you plug in a 3.5mm cable into the stereo it is fine, but when you plug the other end of the cable into something else that's when you get the mild interference. It's not a big deal, as it's only quiet... and really it's not a piece of audiophile equipment it's a portable stereo, but if I know whats causing the noise I might try and fix it. There is no noise when playing cassettes, so I can assume it's grounded OK?
Overall I'm very happy with the mod, the quiet noise is not overly bad and is a small trade off to have an aux input on the unit. One other thing though, I'm not sure if anybody would know... My second tape deck appears to be stuck on high speed mode, weather or not your playing, recording or dubbing... It just runs too fast. The first deck is fine. Could I have possibly knocked a switch or something to cause this? I couldn't find anything after having a look... I don't know if I caused this or not as I didn't test out the tape decks before I installed the line in.
Thanks again
Daniel
PostPosted: Mar Fri 02, 2012 6:36 am
Daniel-
About your background noise problem: No one else has reported it. My 690 has a VERY weak hiss that's barely audible, and it's present in any mode (tuner, CD, tape, or external), but it has nothing to do with the modification. Check all of your work for cold solder joints. A bad solder joint can act as a diode/detector that could potentially pick up local Radio,TV, or Ham stations and introduce that sound into your boom box's amplifier. Failing that, try putting a ~.001UF capacitor from ground to input connection for both the left and right channels. This will usually block external transmitters from getting into your amplifier section.
The aux input modification has no effect on tape speed. Either the unit had that problem before you did the mod, or you made some kind of wiring mistake. Check the 2nd tape's drive belt(s) too- its possible that one of them came out of its pulley groove and it's riding on the pulley's hub. This could cause speedup.
Good luck.
daniel7y wrote:
Hi all
Thanks again
Daniel
Post New Topic Post Reply  [ 45 posts ]  Moderator: Dave Doughty Go to page Previous  1, 2, 3
